2005 Dodge Ram 1500 2 w/d rear end blowing oil out front
I have a 2005 Dodge Ram 1500 2wd p/u truck. My rear end was "whining" for some time now, and my son thought that changing the rear end oil would help out. He removed all the oil from rear end, and replaced with mobil 1 (possibly synthetic?) and a Dodge Mopar additive that he said was needed. Drove truck without incident for one month, but rear end still whining. This morning, on way to church, smelled burning smell and heard loud whining noise. Got out and looked under and saw oil pouring out of rear end housing from where drive shaft connects to rear end. Had no choice but drive back home. It actually locked up a couple of times on the way, but made it back. Housing so hot I swear I thought it was going to catch fire. Am I up the proverbial creek without a paddle? Did he mess up? Is rear end cooked? Any ideas? I appreciate it in advance.
    Brigadier General:
  • 4,088 Answers
The input shaft, gears, seal, and differential are likely toast. The normal rear end lubrication is 90 weight gear lube, not Mobil1 engine oil. The cheapest repair may be a replacement rear end from a wrecking yard--not easy in any situation. The 'whine' that you originally had could be insufficient lubrication or the ring and pinion gears could have been worn or mis-aligned. Worn bearings can also cause this problem. Hope this helps!
Posted on Nov 15, 2009
Need the firing order for a 1998 dodge ram 1500
For the 1998 Dodge Ram 1500 5.2L V8:
It is the same for the 2WD and 4WD
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
..........(back)
_____..........._____
|...8...|..........|...7...|
|...6...|..........|...5...|
|...4...|..........|...3...|
|...2...|..........|...1...|
..........(front)
Distributor:
........(back)
............3
....4..............6...
.......................(+)-screw: rounded-end of Cap
8......................5
(+)-screw: square end of Cap
.....1...............7
..............2
.........(front)
Rotation: Clockwise
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
May 18, 2010 | 1998 Dodge Ram 1500 4WD
Which digit on a 2005 dodge ram identifies the rear axle ratio?
i dont believe the ratio is supplied by the vin but the ratio is written or stamped on the tag on the rear end, or front differential
May 05, 2010 | 2005 Dodge Ram 1500
Where do i put the new transfer case oil on a 2002 DODGE RAM 1500 Truck? please help...
your transfer case controls you 4 wheel drive it is between front wheels it drives the front wheels
Nov 28, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Front end axle loose on 4wd
First slide it into the transmission then back to the rear dif.
May 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2000 dodge ram 1500 front end clicks in 2wd and bucks in 4wd
Sounds like either your hub assembly or front axel universals.
Mar 21, 2009 | 2000 Dodge Ram 1500 Truck
Front end vibrations at highway speeds
sounds like you may have unbalanced tires. take your vehicle to a tire shop and have them balanced
Dec 24, 2008 | 2005 Dodge Ram 1500
Whining coming from washer fluid reservoir area, engine is off?
A whining noise in that area is most likely the power steering pump. Does it do it with the engine running or when the engine is off?
Oct 10, 2008 | 2001 Dodge Ram 1500 Truck 2WD
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
