Question about Dell Dimension 4600 PC Desktop
Computer will not start up. runs for second then shuts down
  • 460 Answers
I used to and at some times still work on that model.. and when i say it needs a new mother board believe it.. have a good day..
Posted on Nov 15, 2009
  • 58 Answers
Given what you've stated it sounds like the power supply is going bad.
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
P8b75-mle will not shut down
Hit control alt delete and look and see how many running programs you, most of the time it is a background running program that locks up the shut down process. On average you should have only 60 to 70 programs running. Reduce these and your start ups and shut downs will be much quicker, there are third party software that can enable you to do this with ease, or you can search google .
Dec 26, 2012 | ASUS - MOTHERBOARDS Asus P8b75-M Le...
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
The computer starts up and then shuts down, then
First things to establish, if you are running from battery whether the laptop is charged, if you are running from AC whether the cable works properly. If both of these are ok, have you made any hardware changes recently? If so, check that the are securley installed and if so then remove if possible. Failing that there may be a problem with the power supply to the motherboard, something you may be able to address if you have an intermediate understanding of internal components.
Nov 13, 2009 | HP Compaq Presario V6000T Notebook
2000 2.0 vw beetle starts then dies
computer possibly has noticed a reason to shut down engine try checing the oil low oil psi will cause the computer to shut down engine before damage occurs
Jun 21, 2009 | 1998 Volkswagen Beetle
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
When i try to shut down my computer it does not shut doen but it gets restart every time
What version of windows are you running? Also, when did this problem start and how old is your PC?
On 2000/XP: On your start menu click on Run and type the following command: SHUTDOWN -s -t 01
This will shut down windows, and then you can safely turn off your computer. You may have to hold the power button for 10 seconds before it turns off.
NOTE: This is not a fix, just a temporary solution.
Oct 02, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
35 people viewed this question
Alun Cox
