Question about Brother SX-4000 Typewriter
How do you reset printwheel? - Brother SX-4000 Typewriter
    Scholar:
  • 49 Answers
The printwheel "homes" everytime the power is turned on. There are many causes of the printwheel losing it's homing during printing. Check that nothing is interfering with the printwheel spinning, like the correction tape, or ribbon. Type slowly and observe the movement ot the hammer to make sure the hammer returns to it's home position every time, if not the machine must be repaired (to retime the hammer cam) . You can removed and reinstall the printwheel to make sure it is seated on its' drive spindle securely. checke that the is no foreign material in the bottom of machine.
Posted on Nov 16, 2009
Mike,My wife is having trouble with a Brother AX-100 typewriter that does not type the letter being struck on the keypad. We don't know how to RESET this model - There is no "CODE" key available, as
The printwheel may be in wrong. Unsnap the printwheel, set it back in and make sure the pin seats in the printwheel when you snap it in. It should spin when you turn the power on.
Or.... it cound be the print hammer solenoid which strikes the hammer to print is cracked and not working correctly (this should be done by a qualified tech)
Hope this helps...
Mike
Oct 01, 2014 | Office Equipment & Supplies
INCORRECT LETTERS
Hi There. Not only check the printwheel to ensure it is locked into place, but then you will need to use the CODE RESET feature.
This should align the printwheel into the proper position.
Kind regards ad Hope this is useful.
Jan 21, 2014 | Smith Corona Wordsmith 200 Typewriter
How do you put the font wheel back in to match up with the keys in a Smith Corona typewriter?
When you put it in, make sure the charachters on the "printwheel"are facing AWAY from you. (towards the paper.) And make sure it is latched in place. Put the ribbon and correction tape back in properly. Turn the machine on. The printwheel should automatically reset itself. If it doesn't, it need professional help
Jan 05, 2011 | Smith Corona SMC10230 Typewriter
The flywheel from my brother ml300 typwriter came off and i don't know how to put it back on
I assume by "flywheel", you are referring to the "printwheel" which is removable from the typewriter by unlatching the print hammer mechanism by pulling the black lever on the right side of the print hammer towards the front of the machine. To install the printwheel, drop the printwheel in its cartridge with the letters facing the paper, then push the print hammer assembly towards the paper to the latched position. Turn on machine, and the printwheel will spin and "home". If printwheel homing is not correct, repeat above procedure with slightly more pressure when latching the printwheel. (The printwheel must latch on to its drive spindle securely). Good Luck
Nov 25, 2009 | Brother ML-300 Typewriter
The keys I strike are not what appears on the paper. Could the print wheel need replaced?
My printwheel also does not print what is typed. took out and put back in now what? How do you reset?
Nov 10, 2009 | Brother SX-4000 Typewriter
Reset code for daisy wheel
check this link on which printwheels work with your model to make sure you have the right one. There is no reset, except after you insert the printwheel and close the cover, it will automatically go to the proper position, unless there is something wrong with it.
See the instructions on page 12 of this manual:
http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Jan 18, 2009 | Brother GX-6750 Typewriter
Some uppercase letters are not printing correctly
make sure ribbon and corr. tape are in properly and not interfering with the free movement of the printwheel. ribbon and tape should be between the two metal fingers and the cardholder. make sure the two fingers are not bent down into the printwheel. check the "fingers" on the printwheel to make sure they are straight. with the printwheel out of the machine, push the printhammer forward and release it to make sure it snaps back freely. if these seem to be okay then it could be a problem with the p/w motor or motherboard, and would need professional help.
Oct 09, 2008 | Brother ML-100 Typewriter
Keyboard is malfunctioning
There are a few things that can cause this. Make sure the correction tape or ribbon is not caught in the printwheel. Make sure the ribbon guide fingers next to the cardholder (the ribbon and corr. tape should be on the other side of these), are not touching the printwheel. Look to make sure there is no forien object interfering with the printwheel. If you have taken the printwheel out, it may not be in properly. Look to see if any of the printwheel fingers are bent forward or backward. Turn machine off and back on, and let it reset. If it still doesn't work the main board may be bad.
Jul 29, 2008 | Brother SX-4000 Typewriter
Typewriter stopped printing
make sure the printwheel is latched into place. if ribbon, corr. tape and printwheel are installed properly, and mach.still doesn't work, you will need a repair shop
Apr 03, 2008 | Brother ML-300 Typewriter
Royal-Adler Stellite 40 mistyping
The printwheel has lost it's home position. Release the lever holding the printwheel, remove it and re-install it. Push the lever toward the platen to lock it in. Turn the typewriter on. The printwheel should spin, the carriage should move to the left and the come back to the left margin. You should be OK after that. Let me know if it helps or not Ed
May 30, 2007 | Royal Satellite 40 Typewriter
Brother SX-4000 Typewriter Logo
159 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
