Question about FixYa Computers & Internet
2001 gallant replaced fuel pump still having problems with stalling, suspect pressure problem. ideas?
  • glorizo Nov 15, 2009
    will let you know as soon as i check it out. have had great success with the experts so far. thank-you
  • 6,927 Answers
Have you any check engine lights,and I did you replace the fuel filter with the replacement of the new fuel pump?There are more sensors that have a lot to do with engine performance,throttle position sensor,mass air flow sensor coolant sensor,idle air control valve.Have you checked the air filter?see if it is restricting air flow?
Posted on Nov 15, 2009
Trouble code P0352
Sorry, this one could be too many things. I would only be guessing. All of the problems like these that have happened to me has to do with fuel pressure from the pump. Trust this one to a mechanic with the right test equipment or you will be spending a lot of money replacing parts that may or may not be the problem.
Jun 12, 2014 | 2001 Ford Focus
2001 ford focus with zetec engine still sputters and stalls when warmed up after replacing fuel pump, fuel filter, and fuel tank pressure sensor
i have ford focus ghia 2.0 2002 model and i have problem with the fuel pump sometimes it works sometimes it doesn't.. when i fill the tank petrol pores out, the pipe next to the filter also comes out, how do i fix the problem?
Dec 08, 2012 | 2001 Ford Focus
I have a start problem and i have a fuel pressure gauge set on the inj rail pressure bieng only 20 psi and then drops to 0 after cranking sound like it initially wants to start then stalls i have about...
fuel pressure regulator may be controlled electrically thru fuel pump on this vehicle, I recommend replacing your fuel pump with new unit and check all fuel lines for posssible leaks
Oct 01, 2010 | 2002 Cadillac Escalade
Last night my sebring stalled out of nowhere and then the check engine light along with the oil pressure light appeared. There was no unusual knocking sounds or anything. I keep the oil changed and up to...
Get it scanned for the check engine light, (mil light), as for the oil light, thats normal due to engine not running and making no oil pressure. was this a sudden stall, with no engine surging, then I suppect a failed cam or crank sensor. if it kind of stalled with engine surge and hesatation, I suspect fuel related, possible fuel pump. 2.4L, 2.7L engine have same sensor issues and ideas. if you need more info, just reply back with the mil code, I will walk you through this problem.
GOOD LUCK, RDJRP.
Jul 17, 2010 | 2001 Chrysler Sebring
I have a Kia Sephia (2001) and it keeps stalling each time I drive over a bump or at the traffic light or make a left or right turn. All spark plugs have been changed and the car has been serviced on a ...
it sounds like a fuel problem. i believe its fuel injected so check the fuel pressure regulator and mainly the pump. the pump tends to go first but if you do change the pump change the filter also. have your local mechanic check the fuel lines.
Feb 19, 2010 | 2001 Kia Sephia
2001 gallant will not start
Start by checking your fuel system. Often when this happens its due to an obstruction in your fuel or air systems. It could be as simple as a clogged fuel filter or a faulty fuel pump.
Jun 08, 2009 | 2001 Mitsubishi Galant
1995 gallant died while i was driving...
Replace the fuel filter it is most likely clogged, I would also get a fuel system maintance done also most garages charge about $50-$75 be sure to get it done.
May 10, 2009 | 1995 Mitsubishi Galant
2001 Chrysler Town & Country mini-van stalling at all speeds
2001 Chrysler Town and Country- Won't start. Turn over. It acts like the fuel is not getting to the engine. After many attempts , it starts and runs like there are no problems. The car has 120,000 and has never had a problem. Is the fule pump bad?
Jun 21, 2008 | 2001 Chrysler Town & Country
Computers & Internet Logo
22 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
