Question about Mitsubishi VS-70601 70" Rear Projection Television
I'm having a problem with my mitsubishi vs-70601. the power will not turn on you can hear the relay click on and off. any help would be greatly appreciated.
  • trevorslc Nov 15, 2009
    I tried to hold the power button in for thirty seconds with the tv plugged in and unplugged, do I have to replace every single capacitor on the power board. None of them are bubbled up on top, I don't know if this makes a difference or not. I disconnected all three of the flyback wires. two of them were clean and one of them was completely covered in black soot, could that possible be the issue? does anyone have any idea where i could buy parts for this?
  • 448 Answers
Disconnect all the cables from the TV then connect the power cord from the TV to different functional wall outlet to check if the TV is powering ON. If the TV is not showing any sign of power then press and hold the power button on the TV for 30 seconds to discharge all the capacitors that may be causing the issue.
If the TV is not powering ON even after performing all the above steps then the capacitors on the power board are burnt out and requires to be replaced.
Posted on Nov 15, 2009
On my VS70601, I checked the fuse per the response, it appears good, but still no power.
hello do you mean the glass fuse inside, if ok then the components inside will need to be checked
shaun
Nov 02, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Have a Mitsubishi vs 70601 shut off by itself one day and wont po
i would think it is going to be the main fuse, open the back of the tv, you will see where the power cord is connected to the board, there will be a glass fuse next to it, you will be able to see if it is bad,----make sure you unplug the tv befor you mess with it
Jan 09, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubshi VS-70601 TvGuide+
I have the same problem have ypu figured it out yet?
May 19, 2008 | Mitsubishi VS-70601 70" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-4507ca
It just click ON and OFF, right? If you hear the hight voltage noise tring start, may be the Tv has bad vartical IC or regulator IC. If you have no experience with electronic you will need a technician to halp you.
Sep 11, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
