Question about Whirlpool Duet GHW9150P Front Load Washer
I was just given the drawer for under my Whirlpool Duet washer, however, I didn't keep the packing bolts that look like they are needed for fastening the washer to the drawer cabinet. If needed, where can I get the bolts?
  • 126 Answers
Searspartsdirect.com , just put in the model # of your pedestal, which is on a tag when you open the drawer. You can use just regular bolts, as long as the head is large enough to stay in.
Posted on Nov 15, 2009
My Whirlpool Duet washer is leaking from the
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do you remove the washer from the pedestal?
not an easy task---try to remove the drawer. there is a bolt going upwards in each corner (inside)
Dec 10, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
My duet front loader is not draining. Water came pouring out of the soap and fabric softener dispenser. There was not a code displayed when this happened
make sure the drawer is closed all the way , and that you don't have a build up of soap in side where the dispensor drawer slides , this could keep the water from going into the washer.
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need new drawer leveling feet
goto Sears.com .. look under parts.. key model # if you have it..
Jan 21, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet GHW9400PWO, Front Panel comes off
There are no fasteners that I know of. I've worked on this model numerous times and have never seen any. There should be screws holding the front panel in place. Remove the lower panel under the door by removing the screws under the bottom edge. HINT: Placing a block of wood under the bottom of the frame to elevate the front feet of the washer off the floor will make it easier to access the screws. The washer is heavy so it may take two people to do this. DO NOT push on the door or the control panel. Use the facing of the washer front panel for leverage. With the screws removed, the panel will drop down, then come off. There should be a mounting screws for the front panel on each side of the washer. Make sure the screws are present and that they are tight. You may just have a screw loose (no pun intended). I hope you find this information helpful. Let me know if you need further assistance.
Sep 26, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
