Question about OKI B4350 Laser Printer
I had one sheet jam. I pulled it out and a corner
I had one sheet jam. I pulled it out and a corner tore off and I don't know how to get to that corner.
    Master:
  • OKI Master
  • 956 Answers
Switch off.
Open all access panels.
Need a good torch light and the longest pair of tweezers you can find.
Then go hunting? Torch should show small piece of paper up. Be gentle but firm, most likely it might tear again, just keep at it.
When clear, do your self a favour, don't use economy paper, its not worth the hassle, a few pence more, little or no hassle.
Good Luck, rem be gentle!!
Posted on Nov 15, 2009
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
The paper had jammed when i was printing, i removed the jammed paper and tried printing again. however, the display on the printer shows paper jammed. what now?
You may have left behind a tiny piece of paper that tore off your sheet as you removed it. Make sure that you have all of the jammed paper and look carefully for any remnants inside. Look to see if the printer did not pick up a second sheet that is still in the system somewhere.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Paper jam! how do i get the sheet out!?
open the toner place and remove the toner so as to remove the remaining papers inside the printer and plow the printer very well
Oct 16, 2009 | Brother HL-2040 Laser Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
My HP7580 all in one has a paper jam. One sheet went through and misfed and a corner of the paper ripped off and did not eject with the main sheet. I can't find the scrap of paper that tore off and no...
I finally found the door on the back of the printer and opened it. The paper was easy to remove at this point. However I would like to say that nowhere in your manual that came with the printer does it show this door nor does the trouble shooting info tell about it. It should think this is something that you would consider adding to the manual!
Nov 23, 2008 | HP Office Equipment & Supplies
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
OKI B4350 Laser Printer Logo
140 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
