Question about Kohler K-4764-0 Zofa Soft Comfort Quiet-Close round-front toilet seat with
A plastic clip that holds the seat to the toilet broke. Is there a repair?
  • 119 Answers
You need to check with Kohler 1-800-4-KOHLER they might offer it they keep changing service parts on us
Posted on Nov 16, 2009
How to replace a toilet seat
There are round and oval seats.... take note of which you need. Back towards the bowls water tank on the toilet seat you will notice two tabs....pop open with a screwdriver. You will see the screws holding the toilet seat in place. .
Reach under the screw there will be a plastic nut. Hold if while you losen the screws with the Screwdriver....remove and replace seat. ... install screws and plastic nuts again.... and your finished. ...5 minute repair
Sep 30, 2014 | Home
Tip
Kohler Toilet 1.6 Gallon Flush Install Tips. We just recently installed two of...
We just recently installed two of these and they work perfectly.
LESSONS LEARNED:
-This is a almost complete in box and needs to only install the tank and seat. It also came with a new wax ring and bolts.
-What you also need is Full ring flange repair kit, (this is a round metal ring that goes over the existing plastic flange on the floor), put in as many screws as you can. On both we broke the plastic flange while installing the bolts. also the second one we also added a washer on the back side of the metal flange repair ring this made the connection even stronger.
-The new bolts that hold the toilet to the floor will be to long and an need to be cut off. Don't just try to brake it off, we ran in to big trouble and is how we broke the flange.
-Lastly go ahead and use Tub sealant and put a bead around the floor and base of toilet, this will keep it more secure and not allow any fluids to seep under the toilet and start smelling.
Hope this tip helps.
R/
David
on Feb 15, 2010 | Plumbing
In pressure Lite flushing system, do we need any pressure?
We just recently installed two of these and love them.
LESSONS LEARNED:
What you also need is also at home depot they have the better flange repair kit, this is a round metal ring that goes over the existing plastic flange on the floor, put in as many screws as you can. On both we broke the plastic flange while installing the bolts. also the second one we also added a washer on the back side of the metal flange repair ring this made the connection even stronger.
R/
David
Feb 14, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I can't unscrew the bolts on my Kohler 3386 rialto toilet to replace the toilet seat.
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Dec 03, 2009 | Kohler K-3386-0 Rialto one-piece...
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
Hello - my toto toilet seat broke where the bolt holds the seat to the toilet
well you can go to home depot and get your self new seat with bolt or you can buy the screws for it
Aug 10, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
How do I replace the toilet holding flangs? Replace toilet seat.
you may want to consider simply repairing the flange rather than replacing it as replacement is major surgery. Go to home depot or a similar store and they will show u the products available to make the flange work for you. Regarding the toilet seat it simply unbolts and a new one gets bolted in. In most cases you unsnap the plastic cover on each side of the rear of the toilet seat and you will see a screw. Use a large flat head screw driver to unscrew it. You may also have to use a wrench or a vise grips on the underside.
Mar 29, 2009 | American Standard Home
How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Aug 27, 2008 | Hansgrohe E & S Accessories 40522000...
Kohler K-4764-0 Zofa Soft Comfort Quiet-Close round-front toilet seat with Logo
311 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
