Question about Exercise & Fitness
Hi my tredmill will turn on but moter wont
Hi my tredmill will turn on but i set speed and it wont run it came up code E2
    New Friend:
  • 64 Answers
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Posted on Nov 18, 2009
Moter turns over but wont start. and windos stops working after moter start.
02 ford/?
wont start, then starts. im confused.
check all fuses. first.
Dec 18, 2013 | 2002 Ford Explorer - XLT - Speed Grille
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Problem is the car's fan runs all the time at 3 when the power is connected, speed selector is set to 1 or 2 runs all the time at 3 speed 4 is operating normally the car is 2008 FORD F250 vm
sounds like the blower moter resester is bad it controls the speed the moter runs at. if thats not it then something in the switch can apart.
Nov 30, 2010 | Ford F-250 Cars & Trucks
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
I have a pro form xp weight loss 620 tredmill and when I turn it on and press start the belt runs for about 1 sec. On the main board in the bottom of the tredmill there is a LED and sometimes it turns off...
Since the motor shroud is off I would like you to manually move the running belt by foot and see if that LED flickers if is does then your speed sensor is working properly. If not then the speed sensor needs to be replaced. The next thing I would be checking is the drive motor, using a fully charge drill battery, lantern battery or even a 9V battery by connecting the two leads coming off the drive motor it should move the motor at approx. 1 mph if it is moving the motor is good. then I suspect the lower board will have to be replaced.
May 17, 2010 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
459 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
