Question about Acer TravelMate 4010 Notebook
Windows can't find a wireless connection - Acer TravelMate 4010 Notebook
  • Judyswolf Nov 19, 2009
    yes
  • Chris Hingee
    Chris Hingee May 11, 2010
    Do you have a wireless router on your network?
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Tip
Enable WZC (Wireless Zero Configuration) and connect to wireless network on...
Windows XP has built in wireless utility which can be used to connect to the wireless network. Though, you can still use the wireless utility software that came with the wireless adapter. Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
These steps will help enable wireless zero configuration on your XP wireless computer and you can connect to your wireless network using it.
on Feb 13, 2010 | Microsoft Windows XP Professional SP2
Tip
How to connect to a wireless network with windows xp (must have a wireless...
  • In the start menu, click "Control Panel"
  • In the Control Panel window, click Switch to Classic View. If the text reads Switch to Category View, then you are already in Classic View and can skip to the next step.
  • In the Control Panel window, double-click Network Connections.
  • In the Network Connections window, right-click on the appropriate wireless network connection, and select View Available Wireless Networks.
  • In the Wireless Network Connection window, select your Wi-Fi (SSID)"Connect".
  • If you don't have a security code on it then In the Wireless Network Connection warning dialog, click "Connect Anyway" .
  • The Wireless Network Connection window will first indicate a status of Acquiring Network Address for your Wi-Fi, and a few seconds later will indicate a status of Connected. You are now connected to your router and can close the window.
on Jan 18, 2010 | Computers & Internet
Running the wizard from the install CD does not find the router and I know the router.modem cables are connected properly... whats next...
It seems you're setting up a wireless network thru your router. The basic steps in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. As of the moment, we need to use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows.
Click the link below for proper cable connections in setting up your wireless network. This also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Feb 12, 2011 | Linksys E3000 Wireless Router
Windows cannot connect to the wireless network
I would remove old cache wireless network connections. Example is when you once connect to a free wireless access at Library or Coffee Shop. Windows save all of these profiles and this will cause problems connecting. Then use Microsoft Wireless Troubleshooting resource:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Good luck
Dec 30, 2009 | Intel PRO/Wireless 3945ABG Network...
How do you connect WIndows Vista to Windows 7 through ADHOC?
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 04, 2009 | Computers & Internet
Lost wireless connection and yet it works with other computers... do I have an on/off switch on a Gateway 600y?
To turn the wireless emitter on or off in Windows XP:
1 Click Start, then click Control Panel. The Control Panel window opens. If your
Control Panel is in Category View, click Network and Internet Connections.
The Network and Internet Connections window opens.
2 Click/Double-click Network Connections. The Network Connections window
opens.
3 Right-click Wireless Network Connection, then click Enable to turn on the
wireless emitter or click Disable to turn off the wireless emitter.
Aug 17, 2009 | Gateway Computers & Internet
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Laptop Wireless Connection Problem
I have previous experience with this wireless connections. I'm not familiar with AT T GSM device. In my experience I found that the manager can play up, but you can switch to windows manager depending on what windows you have. In Windows XP go to your control panel. Click on network connections, then select the wireless network connection. On the screen a window with the network connections should appear. Then on the left hand side down the bottom it will have Change advanced settings, and click on that. Then another screen appears with Wireless Network Connection Properties. Click on Tab Wireless Networks. On that page click on "Use Windows to Configure my wireless network". Once done, click okay or apply if appears. Restart computer and see if windows picks up you wireless connection provided you have WIFI on your laptop! Try that, let me know if you need more help!
Jul 30, 2008 | Computers & Internet
Acer TravelMate 4010 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
