Question about Measuring Tools & Sensors
The innova 3310 multimeter is set for ACV 200 or 500 - but gives no indication when inserted in a live outlet - what am I doing wrong? the thing works on batteries, so it is functional.
  • 288 Answers
Try another recepticle just in case the one you are trying is worn
Posted on Dec 23, 2009
2001 Ultra Classic Battery went bad had to jump it quit charging. have a new battery now only shows 10-12 volts on the meter tried a different regulator with same results. tried to check stater with...
usually it is either the regulator or stator that dies
firstly check stator...(alternator)...set multi mtr at 500ac volts
connect probes (red/blk) to both wires from stator..output voltage should read between 100 acv mid revs to 150 acv mid revs
output to battery should be 13.5v -14.75v dc...if not then regulator is RS ...I used to fit Honda regulators 30amp type with 2 red and 2 green wires ..because it is a 3 phase regulator just disconnect one yellow wire
harley regulators are of poor quality...they have no on off switch like the japanese ones ..in other words when you turn off your ignition the harley regulator is still on
hope this helps
MCS
Mar 08, 2015 | 2001 Harley Davidson FLHTCUI Electra Glide...
Camera not powering up after battery installed. After inserting existing or new battery, camera indicates "This battery cannot be used" and will not power up.
The charger can tell the voltage is high enough, but still not sure the camera will work. Did you check ale contacts also the ones in the camera, are clean and shiny? Only a little spec of dust, can give you lots of trouble. To be sure the batteries are both ok, use a multimeter and check the voltage. On the multi meter the voltage should be just a few tenths of a volt higher than what is printed on the battery. I think your battery must be 3,7 Volt, so at least 3,8 volt should be measured, because the multimeter does not take any current from the battery. My 3,7 Volt Kodak batteries, still give 4,03 and 4,07 volt, three months after they are charged. Those are Li-ion batteries.
As soon as they give less then the printed value just after charging, you know they are not ok anymore.
Nov 21, 2013 | Panasonic LUMIX DMC-TS20 Digital Camera...
Battery Load Test lights do not function
Someone on youtube suggested changing the fuse.
http://www.youtube.com/watch?v=jUuIANsxVtI
Dec 23, 2012 | Innova Equus Products 3320, Auto Ranging...
Dm-60 Has been setting on the counter for a couple of years. Measuring dcv, on a 9v battery, readout is unstable and lower than it should be. Measuring acv, reading is about half what it should be. There...
If batteries are fresh (low batteries give false readings on the meter because the meter uses the batteries to benchmark what it is testing), then you might want to consider taking the meter back even if it has been a couple of years. If that is not possible for you then try calling Greenlee themselves and seeing if there is a warranty on the meter-some meters have 7 year warranties.
Hope this helps, James
Apr 05, 2011 | Greenlee Dm-60 Digital Multimeter
Error 0xc05d2281 what is this, please HP photosmart 3310
These error codes indicate that the product has an internal error condition.
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges' message to display on the control panel.
  • Disconnect the power cord from the back of the product.Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Reply back; If the issue still exist.
Regards,
Riztech
May 02, 2010 | HP Photosmart 3310 Printer
Nokia 3310 is switched off by itself problem osniazi1@gmail.com
try use inserting a new battery, then observe if it still the same problem,,
Feb 25, 2010 | Nokia 3310 Cellular Phone
Mitsubishi tv
The ic IC9C25 is a 1 amp 9 volt regulator, see
IC REGULATOR 9V 1A TO252-3 TR - BA09FP-E2
The multimeter must read an output voltage between 8.45, and 9.45 , if it reads 1.7 then the IC is faulty.
Check the datasheet here
Sep 15, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Cell phone dead
check the batteries..charge them and use it..may the battery must be worn out so replace the batteries...or only keypad lights are on and display is off then replace the display..an new display would b around 300 INR.
Apr 10, 2008 | Nokia 3310 Cellular Phone
Measuring Tools & Sensors Logo
627 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
