Question about Canon EOS 30D Body Only Digital Camera
Trying to clean sensor, but following the manual there should be a setting in the tols menu for sensor cleaning, but there is nothung listed my last chice is format.
  • 4,472 Answers
I assume you have the manual again. If you don't have the pdf it is available here. I assume your referring to the instructions on p. 41.
http://www.canon-30d.com/Canon-EOS-30D-Manual.PDF
You will want to make sure your lens is detached and then perform those steps. Also what is your firmware vesion?
Thank you,
Lee
Posted on Nov 15, 2009
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
How can i clean the sensor?
This is something that should be done by a specialist ,ie Canon repair.
However this can be done by yourself but is extremely risky.I clean my sensor but have learnt the hard way.
Here are some tips for you, i suggest you read carefully first - http://photo.net/equipment/digital/sensorcleaning/
This will apply to most dslr's though some have sensor self-cleaning within the menu.
If you decide to manually clean the sensor, i would suggest you use http://tinyurl.com/yhkweww make sure you list the Camera make and model.
Though accessing Mirror lockup in your menu and using a rocket blower may cure any problems you have.
Do NOT touch the sensor with the rocket blower.
I can guide you through the process, but would recommend you send the camera to Canon for a clean and service.
Nov 11, 2009 | Canon EOS 20Da Digital Camera
Printer can't read ink levels correctly
try to reset ur printer
try this
1 Press Menu/Set, 0, 2. 2 Enter the last two digits of the year. Press Menu/Set. 3 Enter two digits for the month. Press Menu/Set. (For example, enter 09 for September, or 10 for October.) 4 Enter two digits for the day. Press Menu/Set. (For example, enter 06 for 6th.) 5 Enter the time in 24-Hour format. Press Menu/Set. (For example, enter 15:25 for 3:25 P.M.) 6 Press Stop/Exit. The LCD now shows the date and time whenever the MFC is in Fax mode
Jul 24, 2009 | Brother MFC 210C All-In-One InkJet Printer
Techincal
You should be able to set the exposure to "B" when the exposure is set for manual exposure settings. The shutter should stay open (and the mirror up) for as long as you keep the shutter button pressed.
Mar 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Unable to clean
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Solution no. 2. (DCP 115):
Here's how...
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is I assume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set". Do the same for numbers 7, 8 and
3. After you have entered this combination, the purge numeric value will be reseted to 0000.
That's it...
Solution no. 3. (for printers with numeric keypad):
Resetting purge counter on MFC620CN/420CN/410CN/210C and FAX2440C:
1. Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode.
2. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6. Press the 9 key twice to return to the standby state.
Happy Printing!
Sep 13, 2008 | Brother DCP-110C All-In-One InkJet Printer
Pentax K100D black spot on images
To clean the sensor on the K100D . . .
1) Turn the camera on.
2) Press the "Menu" button.
3) Press the right arrow to the "Set-up" tab.
4) Press the down arrow to the "Sensor Cleaning" item on list.
5) Press the right arrow & follow the on-screen instructions.
And don't touch the sensor with anything. (You will damage the sensor).
And don't blow on the sensor. (You will get your spit on the sensor).
I used one of those old rubber blow bulbs that people used to clean their lenses with before the Lens Pen came along.
Take care & Happing Imaging!
Glen
Apr 17, 2008 | Pentax K100D Digital Camera
Evolis Pebble Cleaning Kit
try right clicking the printer and choose properties under the tols tab there is a "printer self clean" try clicking that with the card at the feeder
Feb 26, 2008 | Evolis Pebble Color Card Printer
Cleaning
most canon eos have the cleaning trigger listed under tools.
careful cleaning. follow manual. you can do more harm than you would ever believe if you don't.
good luck
mark
Oct 30, 2007 | Canon EOS 20Da Digital Camera
Canon EOS 30D Body Only Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
