Question about HP Pavilion dv4000 Notebook
Laptop starts up and shows the window screen, then goes grey and then black, and the hard drive light goes off
    President:
  • 2,600 Answers
Sounds like your hard drive is failing. Try this boot up fix using the windows install disc, just to make sure it isn't windows causing the problem.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 16, 2009
Trying to start Lenovo laptop but just the "Lenovo" word shows up & nothing happens
Try to remove your hard drive. The company I work for uses mainly lenovo laptops and we have found if a hard drive goes faulty it will hang at this LENOVO screen. if you remove it and it progresses to the bios (it won't load windows since the hard drive is not in the laptop) you might need to consider replacing the hard drive and reinstalling windows.
Oct 07, 2014 | Lenovo Computers & Internet
Hi, I have a Toshiba Satellite A665-s6055 laptop. I can start it up but it won't load Windows. It just goes to the Windows load screen, then to a black screen with my cursor. Also, I can't start...
The hard drive could be slightly faulty. Try this first.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
May 06, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
On start up the screen goes black . As startup is progressing, the screen shows the dell logo and backgroun, and sometimes a log on query, but , after a few minutes the screen goes to black.
Hi
You probably have or had a virus destroy Windows start up files or you have a bad sector under the start up files. You may be able to slave the hard drive to another system to backup your data, assuming there are no bad sectors. Once you are satisfied that you have all your data then a reformat and operating system restore should solve the problems. If you find bad sectors though, just replace the drive.
Jun 06, 2010 | Dell Inspiron 6000 Notebook
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
A135 S2386 black screen
black screen with a orange light on cd drive hard drive light for a few seconds and goes off
Lubos
Aug 05, 2008 | Acer Aspire 5315 Notebook
Black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Apr 17, 2008 | HP Pavilion dv9000t 17" Notebook Laptop PC...
HP Pavilion dv4000 Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
