Question about JVC GR-X5 Mini DV Digital Camcorder
Cannot install software disk for my JVC GR-DX28EK,
I have the JVC GR-DX28EK,trying to install software disk to edit home movies on my laptop but i guess its not compatable with vista,what should i do?.................
SOURCE: jvc everio editing software
need to use the software that came with the camera (power director)
Posted on Nov 02, 2007
  • 24 Answers
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
Posted on Jan 20, 2008
  • 1463 Answers
SOURCE: JVC camera software GR-D70 for windows vista
have you tried the jvc web site jvc
they may have the drivers you reqiure from here .
Posted on Feb 12, 2008
SOURCE: gr-d73ag in Windows vista
did you go to conrol panel on comp under other hardware to see if it seeing hook up if not show it to
Posted on Feb 16, 2008
  • 377 Answers
SOURCE: jvc camcorder GR D50EK
hi dear
you not ned a driver for this, you just need a fire wire card' better than USB cable
after that, using pinacle, Ulead Video editor or adobe premiere ....softwaare to transfer that
Posted on Mar 21, 2008
SOURCE: JVC GR DVL9800 - Vista won't recognize
I have the same camera and use vista without a problem. However I use the firewire interface and not the USB which might be the explanation.
By the way, I can't find my manual. The date and time don't stay saved for any length of time between use. Is there a baterry that need to be changed and if so where is it?
0 characters
1 Points
Need software so i can download and edit dv tapes onto my pc so i can edit them and put them onto a DVD.
Use Windows Movie Maker it should be installed as part of the Operating System.
A firewire cable is required. 4 to 6 pin for most Desktops or 4 to 4 pin for most Laptops.
Mar 19, 2011 | JVC GR-D240 Mini DV Digital Camcorder
Video camera to pc operation
Probably you need to install camera software first.
Do you have the install disk?
Oct 08, 2008 | JVC GR D370US camcorder Mini DV
Software to edit MPEG2 format film
try the software that came with the camera if not then go to Everio and see if they hae some patches to download good luck
Sep 21, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Jvc gr-dx28ek black screen during recording
if u can see the old videos in playback mode those videos when ur camera was ok then it is
see the link for free repairs from JVC dont worry if u are out of warranty and not on list just call them PLS RATE ME FIXYA for help
Apr 14, 2009 | JVC GR-DX28E Mini DV Digital Camcorder
Transfer movie from mini tape to computer - JVC.....well, hello i found that people have the same problem i do i;ve got this JVC digital camera GR-D770U...and unfirtunately i don't have a software disc...
You can download user manual in PDF format from this link:
but that's not a point. The point is that you can use any video editing software (with no driver), that accepts capture mode starting from standard Windows Movie Maker for beginners to CyberLink PowerDirector, Ulead DVD MovieFactory or similar. This can be made by plugging your camcorder to PC via USB or FireWire (iLink, IEEE1394). Of course you can record to Digital Video Unit Equipment (DVD recorder) if you have one. Good luck!
Jan 28, 2009 | JVC GR-D770 Camcorder
JVC GR-D23E download video
here is a usb driver for JVC cameras from GR-D20 to GR-D70 for windows XP: it's on free polish server
Nov 28, 2008 | JVC GR-D23E Mini DV Digital Camcorder
JVC Camcorder GR-D33U
try this steps
  • first install the driver camed with your camcorder to your pc. this should recognize your computer after the installation.
  • use USB cable to connect your camcorder to your pc.
  • as far as i know jvc is using a software name ulead (because i also have a camcorder and its software is ulead)
  • Try to use Ulead Movie producer, Windows Movie maker or any other software that accepts uploading dv video.(i prefer to use ULEAD movie producer or any Ulead products its easy to use)
  • After uploading it from the ULEAD and editing, save it with any various types of videos you like. (in your case save it in DVD format so that it will easy for you to burn it.)
  • Use NERO after searching the save video file and Burn it in DVD type
I hope you understand my procedures and steps on how to transfer it. if you have further questions just contact me. hope that helps!
thank you for using fixya
Nov 12, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Dowload to pc
If you still have the instruction book, this should tell you in detail. Basically, you need a 'firewire' cable which plugs into your camera and computer. You should get a message on the screen asking if you want to download movies. Be aware they can take a lot of hard disk space. If you have Microsoft software, XP includes a free program called Movie Maker you can use to edit your movie, and other versions probably do too. There are plenty of other software programs to edit a move and burn a DVD and they are not expensive.
Aug 29, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Use firewire cable to coonect to a computer. Transfer the movie from camcorder to the computer (for example using Microsoft Movie Maker - included in Windows XP). Then you can edit it in Movie Maker and save the final movie on the hard disk, DVD or back on DV cassette.
Jan 19, 2008 | JVC Cybercam GR-DX75 Mini DV Digital...
Go to the support menu for home video and then you'll find the downloads.
Dec 21, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
JVC GR-X5 Mini DV Digital Camcorder Logo
56 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
