Question about RCA D52W23 52" HDTV CRT TV
On my D52W23 RCA is just seems bright. we have played with the color settings and still have troubles. plus it just seems blurry how do we fix it??
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
You can lower the master brightness using the screen controls.
The adjusters are usually in the back on a high voltage splitter/focus block.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 15, 2009
How much would it cost to replace a color tube in a RCA HDTV 32 inches?
The cost of replaceing a tube in a d52w23 is unfortanly high..sorry.. if you can find one the last time i replaced a tube cost about 250 for the tube and labor is extensive it takes a exp tech about 2 hours to replace. Are you sure that the tube is at fault? which tube is it. is this set 32 inches? the d52w23 is 52 inches
Nov 03, 2010 | RCA D52W23 52" HDTV CRT TV
Color will not adjust on projection tv
From the sounds of it, you have a convergence problem. This can be fixed in the home without too much trouble if you feel you are comfortable with soldering. Can you please post the mdoel number? That way I can provide you with the parts that will need attention. Also please indicate whether or not you wish to attempt this repair yourself. With this additional information I can either guide you through the repair or give you a ballpark cost for the repair.
Thanks,
Dan
Aug 13, 2008 | RCA Televison & Video
My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA D52W23 52" HDTV CRT TV
D52w23 is blurry need help to fix
it sounds like you may need to clean the mirror inside the set. take off the back(very carefully) and look for the mirror inside and just clean it with a solutin of soap an water or windex. if this does not work have a service tech to check and see if you need a fluid change.
Nov 10, 2009 | RCA D52W23 52" HDTV CRT TV
We adjusted the brightness and the picture went
possibly the light bulb inside the TV is dead. Complicated fix, try to call a technician
Oct 21, 2009 | RCA D52W23 52" HDTV CRT TV
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
52" RCA HDTV projection TV 4 years old and just started getting
This unit needs repair your convergence needs alignment, which with the RCA model needs to be done by a tech and the Blue card is either dead or is dying. You need to take it in and evaluate weather or not it is worth repairing or just wpending the money on a new T.V. - You can expect to pay around $350 - $800 to get this repaired, plus pick up and drop off. I would not endevor to do this myself as there are other things that can be damaged when messing with it.
Dec 08, 2008 | RCA D52W23 52" HDTV CRT TV
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
RCA D52W23 52" HDTV CRT TV Logo
60 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
