Question about JVC XV-N212 DVD Player
Remote for JVC 212 DVD player doesn't operate unless very close to the player. Is this common with this unit, or does it just need a new battery?.
  • 460 Answers
If the batteries in the remote are very weak..
Posted on Nov 15, 2009
I need a new remote
Several sources of replacement OEM remotes are on the internet.
Jun 15, 2016 | JVC XL-SV22 CD Player
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
Sep 18, 2014 | JVC Remote Control RM-STHD5J p/n:RMSTHD5J
My remote doesn't work on the new clarion nx 501 either. The shop that installed it gave me a new one but that doesn't work either? The battery has power but the remote does nothing. Any...
the unit may be faulty from the factory most shops will try every thing other than swapping out the unit because that cost them time and money unless it is a bluetooth remote then the radio will need to be programmed to except the signal the remote is putting out hope this helps if not let me know and i will do more research on that unit good luck
Oct 10, 2011 | Clarion NX501 Car Video Player
I get set 3 when i press the remote and nothing else no matter what i press play etc any suggestions
Try reprogramming the remote so it matches the unit. If you get SET 3 or DVD 3 on the display, chances are the remote's command code is different to the unit, in which case the following may help a bit:
Ensuring new batteries are in the remote, correctly polarised ( + and - ) and with the remote pointed at the unit (while unit is on), press and hold both the [3] and [ENTER/OK] buttons TOGETHER for 5 - 10 seconds, then release. The remote should now fully control the unit.
If it doesn't, check the batteries and repeat the above. The above procedure is a suggestion based on Panasonic DVD recorders and their operation troubleshooting manuals. Give it a try at least.
Aug 14, 2011 | Panasonic DMPBD45 BluRay Player
How to program the TV remote to work with an APEX DVD player? I do not have the APEX DVD code.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Jul 30, 2011 | JVC AV-32D502 32" TV
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
Trying to program our AT&T Uverse remote using the DVD button to program our JVC XV-S500BK/XV-S502SL. Some data shows that the code number is 0623 or is it 0558? The Data sheet with the remote shows...
try all the combinations - the worst that will happen is the unit will not repond to the remote - if not then try the next code - its that simple.
Pease bear in mind that not all functions of the original remote may be available on the universal remote - this is quite often the case unless the universal remote also has a manual learning function
Mar 16, 2010 | Televison & Video
Remote control no longer works
buy a new one,,,(universal remote control)
Jan 30, 2010 | JVC HR-XV1 DVD Player/VCR
JVC XV-N212 DVD Player Logo
91 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
