Flashing F7?What does it mean? - Washing Machines
  • 1 more comment
  • parkerfam692 Nov 15, 2009
    Kenmore model# 911.9321191
    Kenmore Nodel# 911.9321191
  • Nate Stansfield
    Nate Stansfield May 11, 2010
    What is the make and model of this range?
  • 11,896 Answers
F/07 Motor Control Unit Error
The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
Posted on Nov 15, 2009
My stove is flashing F7 02 CODES With constant beeping.
First things first. Brand and Model number. Although most fault codes have are similar across major appliances it is necessary to find a correct solution.
Apr 06, 2016 | Kitchen Ranges
What does F7 mean, why has it become very noisy on spin cycle and leaks occasionally?
THAT MEANS IT REQUIRE ANEW BEARINGS AND OILSEAL......THAT MEANS U NEED A SPECIALIST TO REPLACE THEM.
Feb 24, 2012 | Washing Machines
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
What does F7 flashing and beeping mean?
Hi msalviolo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Oct 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven flashing F7 serial number is jgrp17bew288
F7 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
GE double oven is flashing F7 and beeping
F7 means a stuck button on the membrane pad. You may have to replace the membrane switch pad
Aug 06, 2009 | GE Profile JT955 Electric Double Oven
Beeping & flashing F7
It means one of the keys is stuck or shorted. Shorted Clear/Off Key
due to membrane switch,
Control or connector
May 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
ADP 7966
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
Remove the filter on the floor of the machine, including the metal grill.
Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it.
My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Oct 22, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
I have an GE oven and the display is showing F7 and flashing E6
F7 normally means there is aproblem with the key panel. Many times it needs to be replaced.
Sep 22, 2008 | GE Kitchen Ranges
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
