Question about Kyocera Cell Phones
My Kyocera (Virginobile) used to charge now I can't get it to charge. The charger is putting out 1.5 vdc bur the phone either starts up or turns off when I plug in the charger.HELP
  • shadxxx Nov 15, 2009
    I CAN'T PERFORM THE SUGGESTED SOLUTION
  • 11,896 Answers
It is very common for the ribbon connection cable that goes from battery to main circuit board to become loose or brittle. Usually loose and it needs to be soldered on better. Sometimes the usb connection pins can also become loose.
Posted on Nov 15, 2009
  • Nate Stansfield
    Nate Stansfield Nov 15, 2009
    You can remove all screws to the phone. Purchase solder and soldering iron, and heat the solder with the iron. Solder will drip on to the place you want it to. It dries in 1 minute.
    There are some youtube videos that show how this is done. Or you can purchase new phone or have carrier repair that one.
My kyocera duraforce phone will not charge
change the charging port of the phone
Mar 12, 2016 | Kyocera Cell Phones
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Phone will NOT power up on or off the charger but will tell me "phone is charging" and battery indicator will go up and down
You will need to replace your battery in your phone.
or check you charger and make sure it actually charging.
I would suspect it's the battery
May 28, 2009 | Kyocera wild card Cellular Phone
Kyocera Wildcard charger doesnt work.
You can go to your carriers retail store and use one of their chargers for free. Then you can determine if it is the phone or the charger.
Mar 01, 2009 | Kyocera wild card Cellular Phone
My kyocera
my thing charges but it is always white now. its sad. have you fixed it yet?? and suggestions??
Dec 28, 2007 | Kyocera Slider Cellular Phone
KX5 Slider Sonic
make sure the phone is off, place the charger in the phone, immediately after the phone cuts on, remove the charger
Sep 11, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
Cell Phones Logo
32 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
