Question about Whirlpool Duet GHW9150P Front Load Washer
Fabric softer releases too soon. Fabric softener releases into the washer with the detergent
How do I repair it or reset the washer
Posted on Nov 15, 2009
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Laundry detergent & fabric softener go into the washer at the same time immediately when started, the fabric softener should only be released when rinse cycle begins, how do I fix this?
without knowing what your machine is I would suggest that you start your load with only detergent in it the after it has filled and is agitating add the fabric softener-you may have to pause the cycle to do this-hope this helped-cheers Denny
Oct 21, 2013 | Washing Machines
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
I have no water to fabric softener dispenser I
Google Neptune TL Washer FAV6800AWW
You can get the FAV6800A/FAV9800A Service Manual and get into Service mode and turn on the Cold Water Inlet valve and the Fabric Softer dispenser valve and see if water flows to the Softer reservoir. You may need to replace the dispenser valve.
Pic below. Post in the other forum it's easier to work the issue at a true DIY forum.
Mar 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Just purchased daewoo washer DWD-WD1353RC..it seems the fabric softner is not dispensing and the detergent is barely used. I understand this machine usesHE detergents but it is using very little detergent...
this washer has different detergent concentration levels settings. 1.By holding delay wash then power button at the same time, while unit is off. then a C1,C2,C3 are main detergent concentration settings C1 being regular HE detergent and C3 being very concentrated some detergents tell you X2, X3 S1,S2 are softener B1,B2 are bleach 2. Then use buttons Delay wash to scroll for main detergent Extra rinse for softener Bleach for bleach 3. power button to exit and confirm
hope this helps also in manual and to clean tanks, Manual says to call a 1800# or find the instructions on the web. I've had this washer for a week no problems yet
Jan 31, 2011 | Washing Machines
White residue on clothes
Common usage things to check:
  1. Detergent formulation
    Make sure you're using high quality detergent that contains both sodium carbonate and aluminosilicates. They'll be listed on the ingredient list.
  2. Amount of detergent
    The detergent amounts given on the usage label of the detergent box are for average water hardness (4-9 gpg). If your water is harder than average, or if your clothes are really dirty, you'll need to use slightly more detergent than what's recommended on the box. If you have really hard water, you may need to add a packaged water conditioner to each load, such as CalgonĀ® or Spring RainĀ®.
    If your water is softer than normal, you'll create too many suds, which will retain gookus. In this case, you'd use slightly less detergent than recommended on the box.
  3. Cold water washing
    If you wash clothes in cold water only, the cold water should be in the range of 65-75F. If it's too cold for your hands to comfortably be in the water, it's too cold to activate the detergent.
  4. Overloading
    After the washer is loaded with clothes and then filled with water, there needs to be enough head room in the tub for the clothes to swish around in. A properly loaded washer has clothes loosely placed in the tub up to the top row of holes.
  5. Rinse-added fabric softener
    Some fabric softeners and detergents have a chemical reaction that can create white deposits (also called 'gookus') on the clothes. Try switching brands of fabric softeners or detergents or not using fabric softener at all for a couple of loads.
Dec 31, 2010 | Speed Queen SWT921 Top Load Washer
Just finished 2 washes with my Electrolux (eifl55IRR) washer and both times there were still soap suds in the machine after final rinse and final spin. I used just the right amount of HE detergent as...
Use a compatible fabric softener. The fabric softener not only softens fabric and makes clothes smell nice, but they break down and neutralizes detergents.
Mar 14, 2010 | Electrolux EW1000i Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Leaking soap dispenser
    There should not be suds up that high in the washer. You are experiencing a over sudsing condition and spin is throwing up throw the fill line in the dispenser. Run some fabric softener in a load with no clothes to clean out any hidden suds. Then use only HE (High efficiency) detergent and half of what they recommend! The softer the water the less the soap you use. Sounds like you may be using non HE detergent. My guess if the machine is fine.
    Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    150 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
