Question about Car Audio & Video
Hi there i have a ministry of sound mosca103 but do not have the wiring harness so can you tell me the wiring from the rear 20 pin plug as i will replace this with a hard wired iso lead, you may think why not buy a new lead well nobody stocks one any more, cheers dave.
shaggyrat
  • 1224 Answers
SOURCE: AFTERMARKET REPLACEMENT FOR AUTO ANTENNA
sounds simple
placement of antenna is important this will determine which wires to use
most antenas are in the trunk of vehicle with a wire clip to connect or disconnect
tools needed
test light
find your wire clip running from old antena this will be where test light will be used one side of clip is full powered the other is key powered find good ground tip the test light on first prong light stays on this is full power other will be key powered
now your looking for the simple color wires ok on the back of your sterio there is an atenna wire which is blue this will power on only when sterio is on the other wire
you use test light to find without key in take your test light and find a permannent powered full on wire hot supply then connect antenna into these 2 things
at top the reason i mentioned this is cause the old power antena you can find the right leads in the trunk area where new antenna going to be placed with the test light you might need a second person to help you testing wires you in the back and them in the front turning the key on when you need it it makes things simpler with 2 people
i hope this helped you in your quest for knowledge
Posted on Jun 01, 2008
SOURCE: replacing audio equipment
Asked at a car parts shop and they had the rightadapter being for the car make. Many thanks for responding and being able to help if needed. From Sue.
Posted on Jun 17, 2008
Eagleeyes
  • 199 Answers
SOURCE: wiring colour code
what is your email i will email you the diagram
Mark
Posted on Jul 21, 2008
SOURCE: Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email: aminassian@optusnet.com.au
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
Posted on Jan 26, 2009
  • 26 Answers
SOURCE: Radio Aux feature and not plug connection
http://www.installer.com/cars/by_car.php?carid=6330
Posted on Feb 28, 2009
03 ford expedition audio wiring diagram
sounds like a faulty instrument cluster
Nov 20, 2017 | 2003 Ford Expedition
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 06, 2012 | Toyota Camry Solara Cars & Trucks
I HAVE A KENWOOD DNX9980HD 20 PIN HARNESS THAT CONNECTS TO THE KENWOOD HEAD UNIT. I ALSO HAVE AN AXXESS ASWC (STEERING WHEEL CONTROL MODULE)20 PIN HARNESS THAT CONNECTS TO THE AXXESS ASWC. THE AXXESS...
HI,
If you make a close verification on the back side of kenwood DNX9980HD 20 PIN HARNESS then you can see a Light Blue wire with Yellow stip ( BLUE/YELLOW) on it with a identification mark as "Remote cont". You have connect this wire to the Brown wire with white strip (BROWN/WHITE) from the 20 PIN HARNESS of AXXESS ASWC . There wil be a brown wire also from this 20 PIN HARNESS of AXXESS ASWC, leave it free insulated. It will not use with kenwood radios. You have to check for LIGHT BLUE with WHITE strip. There is also two other blue wires of which one with white strip. You hve to choose the light blue wire.
ok
Aug 06, 2011 | Car Audio & Video
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Alpine 16 Pin Original Head Unit Harness
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Harness available for hooking up blaupunkt bahamas to amp, the connector is a 20 pin and i cant seem to locate this part or is high level output sufficient?
Hi, look for any RCA connectors on the wiring harness or rear of radio - these are the line output connectors - If there are no such connectors then your radio has no support.
Most amps will support hi level input but your sound quality may suffer a little bit because of the extra noise introduced by the stereo amp.
May 05, 2010 | Blaupunkt Bahamas MP46 CD Player
2002 jetta tdi died while shifting into 4th gear
Sorry, not a solution to this car but your other vw 1989 jetta...only way I could get hold of you.
here is your diagram
The following information covers electrical connections and plugs to the rear of the fuse/relay panel. It completes and supplements the information in the appropriate Service or Repair Manual for the fuse/relay panel section and should be used in conjunction with the wiring diagram for the vehicle or system in question. Volkswagen part numbers shown here may or may not match those on your panel, however, if you panel visually matches the diagram, it is correct for your application.
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 171 941 821 D) clear.gif
Connections and plugs on rear of fuse/relay panel:
A Blue 28 pin Instrument cluster wiring harness B Red 28 pin Instrument cluster wiring harness (position 5 open) C Yellow 22 pin Engine compartment/engine management, left side (position 10 open) D White 29 pin Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open) E Black 18 pin Rear wiring harness (position 17 open) G n/a 1 pin 10 individual circuits H Brown 6 pin Air conditioning/coolant fan relay wiring harness K Neutral 5 pin Seat belt warning system/coolant level wiring harness L Grey 4 pin Horn wiring harness L Black 4 pin Headlight/dimmer switch wiring harness M Black 2 pin Steering column switch wiring harness M Black 2 pin Headlight/dimmer switch wiring harness N Red 1 pin Separately fused circuits (glow plug wiring harness) P Red 7 pin 7 single point connectors for terminal 30 circuit R Green 2 pin Open/ECM power supply relay
Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
hope this has resolved your problem
Thankyou
Aug 15, 2009 | 2003 Volkswagen Jetta TDI
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Mosmp078 ministry of sound mp3 player
when i turn on my Ministry Of Sound mp3 player it showing ***Locked*** . i need help
Feb 15, 2008 | Ministry Of Sound MOSMP080 (20 GB) MP3...
Car Audio & Video Logo
220 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
