Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
I am getting error code -0 and 82 PTG-74PVN
I am getting error code -0 and 82 flashing between the two. Unable to determine what is the cause or the fix to it. The blower turns on but then turns off after a few seconds no clicking sound so not sure if its the PCB or the ignitor.
  • 244 Answers
Remove power, disconnect remote terminal. Restore power, open a hot water valve and see if you get any hot water.
HTH,
Mike
Posted on Nov 17, 2009
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
Thermostat is set @120 then drops to 65 and starts flashing. Water get cold. What is the reason . Thanks
Rheem Paloma tankless computer? No error code? One possible cause; Crossover caused by bad single handle faucet cartridge drawing cold water into line causing shut down of tankless burner?
Copy following links for resources:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment as needed.
Gene
hh
Aug 19, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
-0 82 error code PTG-74PVN Rheem tankless
I had the same problem, but when you change the PCB the chip has to be reset regardles of the elevation so it can communicate properly. The rest is easy, Find the DIP Switch located on the top left side of the PCB set switch #1 & #2 to the ON position push and hold the adjustment buttom till the display changes from flashing to illuminating the reset the DIP switch #1 & #2 to the OFF position and you are ready to go.
Aug 21, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Palaoma ptg-42pvn flashing a1 21 code
error code 21 is malfunction of air intake filter switch. You need to check and make sure the air filter door is properly seated and that the front panel is properly installed
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
253 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
