Question about Samsung LE40R74BDX 40 in. LCD Television
How to remove the stand from samsung 860 52" - Samsung LE40R74BDX 40 in. LCD Television
  • 11,896 Answers
  1. Spread the comforter out on a flat surface such as the floor.
  2. Step 2 Lay the Samsung flat-screen television face down on the comforter on the floor.
  3. Step 3 Use the magnetized screwdriver to gently unscrew the four to six screws securing the stand to the television.
  4. Step 4 Remove the screws with the magnetized screwdriver. If you do not have a magnetized screwdriver, cover the end of a normal screwdriver with masking tape with the adhesive side out so that it will catch the screw and pull it from the hole.
  5. Step 5 Pull the stand from the back of the television
  6. Step 6 Mount the television to the wall with wall-mounting hardware you can purchase from any home entertainment store.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Posted on Nov 15, 2009
How do I remove the stand to put my LT19C300 Samsung on the wall
Look for holes in the back of the TV just above the stand. There are screws in those holes that hold the stand on. Shine a light in one to see what kind of fastener it uses. Some are phillips head screws, some use hex head screws. Locate the tool necessary to remove the screws and take all of them out. Have someone help you hold the stand while you lift the TV off the stand.
Mar 02, 2015 | Samsung Televison & Video
Remove stand on Samsung 233 HD
if there is no screw on the bottom of the stand that u can remove there is usually plastic clips that hold the stand in place.
Mar 09, 2014 | Samsung SyncMaster 2333HD 23 in. LCD TV
Samsung t24b350nd how to remove stand
should have a couple of screws holing stand in place. remove screws then lift tv off of stand
Feb 13, 2013 | Samsung T24B350ND 24" LED Monitor
Remove stand samsung 32in
in most cases set has to very carefully be laid on a padded surface face down and the bolts removed to take the stand off.
Jun 16, 2012 | Samsung LN32B460 32 in. LCD HDTV
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Samsung LN37b650 television stand removal. how do you remove the stand on the set to mount on wall
Mounting on the wall, be sure use the short screws and no power tools. Hopefully it can help you and get a good commend.4933675.gif
Jun 10, 2010 | Samsung Televison & Video
Removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung
On the back of the tv at the top of the stand will be four silver screws, remove those with the set laying on it's face or the tv may fall over. after those are removed the stand will slide out of the bottom of the tv. Hope this helps.
Mar 11, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
589 people viewed this question
Jerry Greenberg
Jerry Greenberg
