Question about LG DLG2524 Gas Dryer
Our LG DLG2524W gas dryer has a cracked drum. It's probably about 4 years old and is making a thumping sound when drying. This is when we discovered a small crack near the seam inside the drum. How do we go about replacing it?
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Dryer makes a thumping sound with or without anything in it
Look for a crack in the seam, where the stainless steel drum is welded together, either at the front or back edge of the drum. If weld is cracked, replace drum.
Jan 31, 2011 | LG D5966 Gas Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
LG dryer making unbelievable noise!!! Loud thumping noise. Took top off and drum is cracked seam where it is welded. This may be the cause of the noise.
Same problem here. Half of my LG appliances have failed within 2 years. Stay away from LG!!! They look pretty, though.
Feb 28, 2009 | LG DLG3788W Gas Dryer
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Jan 16, 2009 | LG DLG3788W Gas Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
LG DLG2524 Gas Dryer Logo
122 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
