Question about Dell Wireless 2350 Router
Connection cuts in and out. - Dell Wireless 2350 Router
  • Dell Master
  • 32,281 Answers
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Nov 15, 2009
Wiring pigtail input speed sensor on my 2000 sonata. The new plug came with three white wires but the wires from car are different colors. color wiring diagram ?
the connector is the same on both the old harness and the new pigtail. As long as you orientate the connectors the same way you just match up the wires. let me try to explain it this way. If you hold the old connector so the part that holds the connector to the sensor is facing up. Hold the new connector exactly the same way. cut the left wire on both and connect the new connector wire to the old wiring harness. Then cut the center wire and connect them. then cut the right wire and connect. No wiring diagram needed.
One thing I will add is to stagger the new connections. Meaning do nut cut them at the place. Cut one wire then cut the next about an inch or so further and then cut the next about an inch or so further than that. This will prevent the new connections from potentially shorting to each other and will keep the harness from becoming really bulky with all the but connectors in the same location.
Oct 02, 2015 | Cars & Trucks
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
How do I put a light switch on a extetion cord
You want a light switch on extension cord.
What kind of light switch do you have? You posted under GFCI device which is totally different than ordinary wall switch.
And what type of extension cord?
Add a comment with more information.
If ordinary light switch is installed on 3-wire outdoor extension cord:
Slice open the side of cord and you see 3 wires: black, white and green.
Cut the black wire in half and connect each end to brass screw on light switch.
If ordinary light switch is install on indoor 2-wire extension cord.
Look at plug and notice there is a wide blade and narrow blade.
Narrow blade is hot. You want the wire connected to narrow blade.
Cut that wire in half, but do not cut other wire.
Connect each end of wire to brass screw on light switch
If you want to install line switch onto indoor 2-wire extension cord:
Narrow blade is connected to hot wire.
Open line switch.
Connect each end of black wire to brass screw. OR if no screws, then place cut wire in open grooves.
Tuck other wire into groove and then reassemble switch.
Jul 05, 2011 | Leviton 8299 Combination Switch / Smart...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Im not sure if its my amp or my subwoofer but it will cut out when i play differnt songs?
Can you be more specific, when you say that it cuts out while you play different songs ?
Does that mean any song cuts in and out...or only on some cd's ?
I'm thinking either your cd's are scratched...which is the easiest solution..The next one involves your amp.
Check and make sure the ground wire for the amp is properly grounded. This means the connection on the end of the ground wire is connected to your cars frame (bare metal) if it isn't then your amp will cut in and out hence your sub cutting in and out.
This is a very common problem and shouldn't be hard to fix. Just make sure the end is secure.
Post back if you have any further question's or comments. Thank you for choosing Fixya!
Nov 11, 2009 | Rockford Fosgate Car Audio & Video
Motor will not cut on
check the motor resistance, check the connection to the motor. Thermistor may be cut the connection.
Jun 14, 2009 | DeLonghi DE500 Dehumidifier
WIreless router - internet connection cuts out
there might be a signal problem repair the connection to change its ip address by right clicking on the connection icon which is found at the bottom left beside the clock if the problem still persists, check the cables of the router
Feb 10, 2009 | Acer Aspire 5100 Notebook
Dell Wireless 2350 Router Logo
610 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
