Question about HP LaserJet 1020 Printer
Want continuous feed for envelopes; keep getting Interactive Msg.
Need to print 850 envelopes and between each I get the ''interactive services'' message which means 4 clicks x 850 times! I want to have continuous feed just like paper. I have Windows Vista and am using Word for my envelope software. I've tried both manual feed and auto select with the same "interactive Services" message between each envelope printing. In the properties tab, I have tried both "letter" and "10 Envelopes" with the same result.
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Posted on Jun 02, 2007
SOURCE: Printer Error When Printing Envelopes
I had problems printing 4 X 6, and found out that I needed to go into the printer mode, and change the tray feed from "main tray" to photo tray.  Try that one.
Posted on Apr 25, 2008
  • 3422 Answers
SOURCE: Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Posted on Aug 17, 2008
SOURCE: Envelopes all come out of the printer wrinkled
Open the back of the printer. You will see 2 little blue levers on either side. Put them in the opposite direction, that is, if they are up, snap them down. I dont know the mechanics of this, but it worked for me.
Posted on Nov 07, 2008
  • 47 Answers
SOURCE: problems printing envelopes using Vista
Hi Jeanne
This seems to be a driver issue.
Don't know how familiar you are with your pc and printer, but there is some ways you can try.
First try, rightclick my computer and choose properties, then choose device manager. search up lj1020 printer in list and rightclick it. Choose update driver, let Vista search for it.
Second try, download Lj1020 driver from hp.com, save it on your desctop and zip up the file. Go to controlpanel, printers, rightclick Lj1020, choose properties, advance, click update driver and when wizard ask for driver, choose have disc and let the wizard search in the unzipped folder you have download from HP
Posted on Jan 05, 2009
Why everytime i try to print something on my printer it would keep saying "Interactive services dialog detection"?
I'm not sure what windows version you are using, but try this...
1. Open Control Panel
2. Double click 'Administrative Services'
3. Double-click "Services"
4. Right click - 'Interactive Services' from list in Window
5. Select 'Stop'
6. Right click - select Properties
7. In 'Startup type' select 'Disable'
8. Click "OK"
Restart your windows just to make sure it's work.
Nov 09, 2013 | Dell Computers & Internet
Fatal error
Copy the file config.qvm and other .qvm files from C:/program files/eidos interactive/progect igi/pc to C:/program files/eidos interactive/progect igi/pc/common/ai
May 21, 2013 | Video Game Consoles & Games
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Interactive services box keeps coming up after installing google chrome and can't get rid of it
Unfortunately,the question you had asked is persisting issue in Google Chrome and the developers at Google are yet to fix it.They have not provided the workaround. But you can stop this interactive dialog box by following these steps:
1. Open Services.msc by Start->Run->services.msc
2. Double click on the entry 'Interactive Services Detection'
3. Click Stop button(if it is enabled) and change startup type to Disabled.
You can find this raised as issue in Google Code page here
You can see people discussing this in Google Forums here
Cheers!!
Nov 22, 2011 | Google Chrome
Print enevolopes
You are correct. There are no settings listed for envelopes at the Toshiba Interactive Tutorial.
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Jan 29, 2009 | Dell 3100cn Laser Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Hp potosmart c3180 all-in-one series
Open and set the preferences to turn-off the interactive services.
Jan 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
EPSON SYLUS C80 indicates "printer error: paper jam"
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 21, 2006 | Epson Stylus C80 InkJet Printer
HP LaserJet 1020 Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
