Question about Traulsen Reach in Freezer - G22010
I need to know how to remove old gaskets from a traulsen
  • Traulsen Master
  • 1,169 Answers
Https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20G-Manual%20(3-09).pdf
see if you can access this site and get the manual. It has instructions on how to do the gaskets.
Posted on Jun 26, 2010
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)...
Regardless of the design...
THERE are only two reasons for excessive FROST.
- massive air intrusion (check seals & gaskets)
- defective defrost circuit (check defrost timer/controller)...
EZ trouble to fix...
Post comment reply: 7/3/2016...
In general... there are only three elements to the defrost circuit:
- 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present).
- 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all).
- 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).
Anytime you don't feel you've got this surrounded just comment me back... I'll be around.
Go to Bing homepage
http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
Jul 02, 2016 | Traulsen Freezers
What is the operating pressure of a g22010
depends on refrigerant being used, the ambient it is working in, the desired box temp as a general rule. gotta have more info.
Aug 11, 2012 | Traulsen Reach in Freezer - G22010
Where can i order a door gasket for traulsen g22010
try Rick at "Restaurant Parts and More". They will need model and serial to get what you need. 1-888-814-1110. That is where I get my parts from.
Jan 13, 2011 | Traulsen Reach in Freezer - G22010
How to find age of freezer
You can go to this web site and call them or put your model in and it willl give you date of manufacture. It should be on the back of the unit on a plate that is rivitoed on or on the inside of the door pannel. heres the site.
http://www.traulsen.com/products/refrigerators-freezers/
Nov 11, 2009 | Freezers
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Traulsen GLT232NUT which is now G22010
check for a good neutral. Sounds like that's the place to start. Check from the unit to the breaker.
let me know if I can be of any further help.
Aug 25, 2008 | Traulsen Reach in Freezer - G22010
Traulsen freezer urns for about 2 weeks then stops getting cold enough
Will it restart again? How old is this freezer? Could be start relay loose or a burned wire connection, worn out compressor. Let us Know what you find
Oct 12, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen Reach in Freezer - G22010 Logo
102 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
