Question about HP Pavilion Media Center TV m7680n PC PC Desktop
How do i remove the secondary hard drive of an hp m7680n?
    Problem Solver:
  • 11 Answers
There are simple ways of doing that, usually it has 4 screws, take off the 2 covers that the pc has and take a look, also there is another way too, ones you do the first one make sure it doesnt have a locker that you need to move down or another way before you can remove the hard drive.
Posted on Nov 15, 2009
  • 62 Answers
As far as my knowledge serves me, I have never seen a manufacturer supplying a machine with 2 Hard drives. May be they have partitioned it that way. You can reformat your machine and make it a single partition.
Can personal info be accessed with hard drive removed?
Yes, as it'll read it as a secondary hard drive. I assume you have another PC to load this hard drive into.
Jul 21, 2014 | HP Pavillion ZV6000 Notebook
HP Pavilion Media Center TV m7680n beep codes at start
How many beep codes?
Beep codes depending on how many can detect defective video display card, defective memory etc.
Jul 07, 2014 | HP Pavilion Media Center TV m7680n PC PC...
My computer won't boot and I want to remove the C drive but cannot figure out how to get to it. I've removed the side panels and can see two screw heads holding the drive but there isn't any clearance to...
What makes you think your drive is the issue?
Sometimes PC's won't boot because of a bad connection to the memory. I have seen this. When there is no response for the video. If this is the case, it could be resolved by removing the memory and cleaning with a pencil eraser and reinstalling the memory.
As far as removing the drive, often the drive screws into a carrier of some sort. Removing the drive may be a matter of finding the right place to press to release the drive, so it slides out of the machine.
Mar 02, 2014 | HP Pavilion Media Center TV m7680n PC PC...
Hp pavillion m7680n win xp freezes
The problem seems to be with RAM. Remove your RAM after switching the PC off and clean the contacts array carefully with a dry cloth, rub a little if required with a slightly coarse cloth. Put it back, hopefully will solve your problem.
Jan 14, 2012 | HP Pavilion m7680n PC Desktop
Damaged motherboard, how do I get all the data backed up for installation on other computer??
there would be 2 solutions to this question
1. remove the hard drive and install it inside the new PC as a secondary hard drive. and copy your data off
2. remove the hard drive and put it in an external USB case, then plug it into the USB on the new PC. they look like this http://compreviews.about.com/library/graphics/BelUSB2parts.jpg there are many different brands most PC shops have them.
Nov 04, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
How do I remove the drive bay on an hp m7680n so I can get to the motherboard?
Disconnect the "power" and "data" cables from the hard-drive.
The drive-cage is probably either:
* held-in by a few screws; so, use a screwdriver to remove the screws. If it does not immediately come loose, it will slide out, like a drawer in a cabinet.
* held-in by pressure -- press and hold a lever to "unlock" the drive-cage from the drive-bay, and then slide it out.
Apr 10, 2010 | HP Pavilion Media Center TV m7680n PC PC...
Use wd5000 from an HP as External
The best way is to use a desktop system. Leave one hard drive plugged into the primary IDE connector and unplug the CD-rom from the secondary connector and plug the other hard drive into that cable. Reboot your computer and they will show as a C and D drive.
Aug 16, 2009 | Western Digital Caviar SE16 (WD5000AAKS)...
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
Is there any way to retrieve data from hard drive before sending it to the HP repair center? HP laptop recalled. No monitor. External monitor does not work either.
The only way is to remove the hard disk from your laptop. It is usually easy. Remove the cover from the back of your laptop, take the hard disk, put it in a rack, then transfer the data on another computer.
Mar 16, 2009 | HP Pavilion dv2000t Notebook
I have a SimpleTech 250 GB external hard drive and would like to transfer the data from the hard drive onto my new HP laptop which is running on Windows Vista. However, when I try to sync, the name of my...
U can remove the drive from the external unit and hook it up to your vista computer as a secondary drive. Boot up the vista, use windows explorer, and transfer the data from the secondary drive to either your primary or a usb stick.
Jun 25, 2017 | SimpleTech (sti-u2f36/250) 250 GB Hard...
HP Pavilion Media Center TV m7680n PC PC Desktop Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
