Question about Magnum DeltaForce CB Radio
I have an old K40 radio and K40 processor mic and cannot find the wiring for the mic.
  • 141 Answers
K40 mic wiring Code:
Pin1 Audio-White
Pin2 Shield
Pin3 Receive-Black
Pin4 Transmit-Red
Posted on Jan 30, 2010
    Champion:
  • 219 Answers
Have you checked out cbtricks.com
Posted on Nov 21, 2009
I have a k40-7 CB radio lights work but no receive or transmitt. Just a low hiss when powered on that gets louder when I key the mic. I don't have the stock mic could this be the problem?
yes , It sounds like an internal problem.take it to a tech or send it back.They will probably ask you to describe what its doing .
Apr 06, 2016 | Radio Communications
The radio recieves great rf power works rodger beep works throws a good strong signal on other radios has a new mic but no modulation
Is this new mic wired for your radio? just because it fits the socket doesnt mean its right. Did the old mic do the same thing reason why you got the new one? just sounds more like a loose wire at the jack where the mic plugs in? has that connector ever been loose or needed tightened at any time?
Jan 03, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
Replace lead wire on k40 antenna
the coax doesnt solder it screws in twist the replacement wire clockwise to secure it they have it ehow tech its a website because I had the same question
Aug 17, 2012 | K40 57.25 Base Load CB Antenna Kit with...
Radio shack trc-496 mic
if this one is a din type mic they should all be the same wiring and one mic should fit all of the same type.
Aug 17, 2012 | Radio Shack Radio Communications
I have the new galaxy 959 and i purchased new coax and k40 helicoil 20,000 watt antenna but my swrs are too high and my radio is acting like its keyed up or should i say the needle swings pn it very own as...
Your radio shouldn't be keying on it's own no matter where your SWR's are at. I would start simple by checking your mic plug, then inside the mic for cold solder joints, or shorts. Do this after you borrow a compatible mic and try the key-up. Just don't key very long before you get your standing wave ratio in check. I'm talking like 1 second.
May 23, 2011 | Radio Communications
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Dec 23, 2007 | Magnum OmegaForce S45 CB Radio
Uniden pc 78 elite cb
Hi, This is a link to your old post re SWR 3....http://www.fixya.com/support/t180697-pc78_elite_cb As stated SWR 3 is too high, it should be 1.5 or lower. Fiberglass antenna are kinda notorious in setup and experience wise have not performed well or at all. Maybe you should try a different antenna (metal rod). Some good brands/models I have tried with very good results are K40, Hokushin, Comet, Oscar, Maldol, Daiwa. To check if you can receive, stick an ordinay length of wire ('bout 9' long) at the center of your radio's connector. RX should work (pls don't key the mic or TX).
Aug 12, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
169 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
