Question about Mitsubishi HC1500 DLP Projector
Zap sound plugging PS3 into projector HDMI. Now ports don't work.
I was plugging a PS3 into the HDMI port of my my Mitsubishi HC1500 projector and I heard a zap sound and now the HDMI, as well as VGA and component inputs on the projector no longer work. The composite and S-Video inputs still work for some reason though. Both the projector and PS3 were plugged into grounded sockets (though the PS3 was plugged into a step down voltage converter first) so I wouldn't have thought that static electricity could be a problem. I was wondering if perhaps there might have been a fuse inside that burned out and needs to be replaced, or if the inputs are fried and I need to get them replaced. Any help would be greatly appreciated as the unit is no longer under warranty. Thanks.
  • 1 more comment
  • spmact Nov 21, 2009
    Is there a chance of this being a simple repair, or will major circuits have to be replaced?
  • spmact Nov 22, 2009
    So you think it's the step down voltage converter that did it?  I was using it because we have 220V electricity here, but the PS3 is an American model so it would need 110V.
    Do you think it would be simple enough to replace that part, or was there some major damage done?
  • spmact Nov 23, 2009
    Thanks. There's warnings about not opening the unit due to latent charge inside, so I'll take it to a repair shop and tell them about the diode.
    Guru:
  • 773 Answers
Normally fuses do not make a zapping sound when they blow. Sounds like that are never good.
You are most likely going to have to bring the tv in for repair.
If you are brave and confident you can open the tv and look for burnt parts. Its most likely just a diode. if you find a black part that looks like a big black diode, you can replace it with n1004 diode. They are usually used as circuit protection. Beings you plug things in to it, it may have them to protect the rest of the tv is if something is hooked up wrong or goes bad while hooked up to it.
the diode will be near the plugs.
repair shops will replace the whole input board. you may also be able to find online the replacement board.
Posted on Nov 23, 2009
    Genius:
  • 1,112 Answers
Hello Spmact: Unfortunely you may of blown the input board assembly. There sounds like you had some voltage on that HDMI Cable. I am not sure why you were using a step-down voltage converter unless you were steping in down from 220VAC to 120VAC. There are no fuses on the A/V input signal board, you may of blown the Audio/Video converter and switching IC's on the board. I recommend you not use the step-down converter on the PS3, Even though you were grounded the converter may be faulty and producing ac feedback into the PS3.
Posted on Nov 22, 2009
    Top Expert:
  • Mitsubishi Master
  • 75,822 Answers
U have almost certainly burned out the input circuit for the HDMI, this was most likely caused by static build up or a difference in ground potential between the two devices, there is no fuse for this input, u will need to have the unit repaired.
Posted on Nov 17, 2009
  • yadayada
    yadayada Nov 23, 2009
    you can open it up if u unplug the unit fro 10 minutes before getting into the chassis.
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
How can I connect PS3 to ACER X110P Projector
does the projector have an HDMI port?
i would buy the cable that is HDMI from the PS3 (unless it has HDMI already)
HDMI converter (HDMI to DVI or VGA) typically don't work well because you are changing the signal from digital to analog through a cable. you want to use a cable that is the same on both ends.
Nov 09, 2012 | Acer Computers & Internet
How do I hook up a playstation 3 to my mitsubishi medallion hd 1080
The best way to hook up is via the HDMI port. Connect a HDMI cable from the PS3's HDMI port the tv's HDMI port. As soon as you power the PS3 and tv on, you should see the initial setup screen.If it does not dispay press and hold the power button of the PS3 for about 5-10 seconds till you hear a couple of beeps and the initial setup screen. After that its just following on screen instrucions to choose your language, resolution(1080i for best quality), aspect ratio(16:9 works best for large screen tvs) etc., If there is some setting that you are unsure about as to what you should choose, let me know and I will help you with that.
Sai.
Apr 28, 2011 | Mitsubishi Televison & Video
We have a ps3 with HDMI cable, hooked up to a mitsubishi HC1500 projector. Everything was working fine yesterday but today there is no sound on the ps3. We get sound with tv and hddvd. I have put it on...
There may be any speaker problem.............
The possibilities are
1> to change the speaker by psp repair shop
2> or any loose connection
3>any can change in your psp settings
you can take your psp to repair shop or else download the repair guide which will help you to get rid of many problem
Click Here to download repair guide
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Mitsubishi hc1500 banding
If you're using the VGA port, you'll see the banding because it's not really showing 720p, it's doing scaling (I'm not sure from what resolutions it's scaling). So, even though you're using VGA at 1280x720, the scaling is still going on and it's showing the banding.
You have to use HDMI to get true 720p.
Dec 09, 2007 | Mitsubishi ColorView XL30U Multimedia...
Optical sound and HDMI sound problem
It SHOULD remember your preferences and you shouldn't have to select optical audio output every time you turn on your PS3; something is definitely wrong there to start with... As for a solution? I can only suggest checking that all your other equipment is functioning correctly before having to conclude that your PS3 is having some problems.
Sep 17, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi HC1500 DLP Projector Logo
261 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
