Question about Casablanca Fan (TRIH45) Ceiling
My fan does not operate.my light switch turns on light however to shut it off i must use the fan switch.Is the switch my problem.
I have a pull switch in my bathroom..which is wired up from the mains and works fine...i would like to add a ceiling fan onto this light switch .the switch is wired up simply with 2 red wires-1 goes to L1 to other to COM. HOW DO I WIRE THE LIVE AND NETRAL WIRE FROM THE FAN SO IT GOES ON AND OFF WITH LIGHT. please help.
Posted on Nov 17, 2012
    Novelist:
  • 145 Answers
It sounds to me like there is a wiring problem. The light is connected at the fan and at the wall switch so thats why when you turn the switch on at the wall it can be controlled at the fan as well. It sounds to me as though the actual fan motor to run the fan is not connected to the power circuit so the wiring needs to be looked at,
Posted on Apr 28, 2010
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
Remote required to turn on light but fan turns on with light switch
Before you conclude the fan was wired incorrectly, try this:
1. Shut off power to the fan (at the circuit breaker)
2. Remove batteries from the remote and press all the buttons to eliminate the possibility of a stuck button. Reinstall batteries
3. Turn on power to the fan and try operation
Jan 23, 2013 | Hunter 28096 Westminster 52" Ceiling Fan...
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Hampton Bay cieling fan. Fan will not operate without light being on. Is there a wiring problem or a fix for this
Isn't there a pull chain to shut off the light? If you only had a light there before and it was controlled by a single switch, that switch will now turn on the fan and light and you have to pull the chain to shut the light off and pull a different chain to turn the fan on and select speed.
Gary
Apr 20, 2011 | Dryers
Connected wires following instructions, but lights and fan do not work
OK, here we go. Hi, WoobieDog here. First, try to operate the pull chains on the side of the fan, usually one for the fan, one for the light. If this doesn't fix the problem, proceed as follows. What else is on the same circuit as the fan? Usually there is more than one light on a circuit. Do the other devices still work? If NO, the problem is probably your breaker. If the other devices do work, the problem is probably at the fan or the wall switch. Trip the breaker on the circuit that the fan operates on, and turn the switch to "off " at the wall. With the fan still mounted, gain access to the wires at the ceiling. Where you connected the wires, test for loose connections and visually inspect each wiring connection. When you remove each wire nut, you should see both wires making a good connection to each other and that the wire nut was making the twisted wire connection more secure. Make sure that you have connected the wires in the proper manner, that is that the fan motor wire (usually black) is connected to the proper switch at the wall for on/off operation and that the light wire (usually blue) is either connected to the light switch or to the same hot line as the motor wire if you are using the pull chains and a single wall switch. Don't overlook the neutral (white wire) connection, as a bad connection on this line will prevent both the motor and the light from working, as you described. If all is well there, close the wires back up under the mounting bracket. With the breaker still tripped to the off position, operate the forward/reverse slide switch on the side of the fan, if equipped. Put everything at the fan back to operating conditions. Turn the breaker back on. Operate the wall switch/switches. Operate the pull chains as these are additional switches inside of the fan and light.
Hope this was helpful. --WoobieDog--
Jul 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No longer works
First check the fuses,the switches, sometime corrosion can cover the contact and check also the thermal fuse.......
Feb 09, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Casablanca Fan (TRIH45) Ceiling Logo
186 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
