Question about AOC LM729 17" LCD Monitor
The monitor won't come on. - AOC LM729 17" LCD Monitor
  • 4 Answers
Is it plugged in. is it turned on is the outlet or power strip on is there power to it from the wall
Posted on Nov 15, 2009
Monitor won,t wake up from sleep mode
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 20, 2014 | HP 2009M Monitor
Won't pass smog due to OBD
Find someone with "VAGcom" or VCDS cable and software.
Nov 16, 2017 | 2001 Audi TT
Monitor won't go on
What to you mean by Monitor won't go on? Are you saying the power on the monitor will not turn on? Are you saying the Monitor is on, but there is nothing showing on the screen? Also it would help if we know what kind of computer and what operating system.
Mar 22, 2012 | HP G60-235DX Notebook
Monitor won't go on
Mar 22, 2012 | HP Pavilion G60-235DX notebook
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
AOC LM729 17" LCD Monitor Logo
55 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
