Question about Cell Phones
My samsung searching svc i try to make call and it only shows me cdma service not availible.need users code to go into settings to fix can u help me
Please help me unlock my cel. It won't let me do set up. I want to use wifi w/o ph svc. It is a cricket samsung galaxy amp 2 model # am-j120az us and the imei # is 35641**********. Thank you!
Google DFS CDMA, and download the free version, have your phone on and drivers installed so your PC shows , modem, port and adb interface in device manager, on the phone, you most likely have to set USB Debugging under developer options, if your settings does not have developer options you will first have to go to about phone, software version and tap kernel and you should see a message after about 8 taps that tells you how many taps left to be developer, if you do not get the message, then try the same on the firmware window, if you still fail to see the message then go back, under settings, go to security tab and you should see it there, also while you are there be sure unknown devices has a check mark in its box, if you have done the steps correctly device manager should show your phone model and make. To get the unlock code using DFS CDMA you connect your phone to the PC, let it install drivers, if they have not already been installed. Set DFS port speed 115200, ignore SPC, click on the port button and you should see the phone modem and port, put a check by them, simply click on the modem and the port, at the bottom of the software window you should see that your phone is online, navigate to memory tab, and you should see a drop down menu that shows options like Ram, SDRam, ect., scroll to the bottom option, CLETS I believe, then just start the search of memory, you should see a time amount left for it to finish, it will show a very long time , but you usually do not need to wait more than a couple hours, if you highlight SPC in the left column, and it has gotten the code, you should see a hex number appear in the right column, click to highlight the hex number and it should show your phones 6 digit SPC , if you need to network unlock the phone then click on each option and the codes it did find will appear as a hex in the right column, if you did not get any hex numbers, you must let it keep searching, pay attention to the bottom part of the software , the window will show how many kb's a second it interesting as well as time to complete, if your dots are red and not green then the phone is offline, green to Amber will still work, red will not....good luck
Aug 02, 2016 | Samsung Cell Phones
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
My cell phone showed 'searching svc' for days. If I dial a number I get the message 'cdma' and I do not find that term in the sv book. I am very frustrated and at 90 years not very patient. My cell...
Code-Division Multiple Access (CDMA) smartphones are cellular phones that use CDMA digital wireless technology.
It is a setting on your phone which may have been set eroneously. No know which phone you have, I can only tell you in general, to go to the menu/setup of your phone. under networks you will see different choices. ie GSM, EVO . Select each one differently to see which one works. You can also call your Phone provider support for help with this.
Good luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 21, 2011 | Samsung Computers & Internet
I do not know the security code to my samsung glide. It is not the last 4 digits of my number. Any way to fix it?
you can try downloading samsung phone service tools light and the dll file for the glyde .. if you can get the software to see the phone it should show you the lock code. Another software that can show that to you is cdma workshop v 2.7. good luck
Jun 10, 2010 | Cell Phones
Cdma service not available after phone fell in water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Feb 12, 2010 | Samsung SCH-a870 Cellular Phone
My phone says searching for svc how do i get it?
That just means you have no reception. Have a look at:
Menu -> settings -> Phone -> Network
Check that network selection is on automatic. If you still don't have any reception you might want to consider changing provider.
Best regards,
Jul 09, 2009 | Samsung SCH-a870 Cellular Phone
How to fix my NAM on my samsung sch 700 cell phone
OMG my phone is doing that too.... i believe that you can take it to your Cell phone service provider and have them unlock it for you. to do this you must go to a technician. the problem that happened was that i knocked my phone off the network so basically its usless at this point so i will need a new phone unless they find out the code so if they cant fix it your going to have to get a new phone
Jun 03, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
CDMA service
ughh my phone says the same thing wtf is wrong
Sep 29, 2008 | Samsung SCH-a870 Cellular Phone
Searching SVC and no CDMA
hi! may be the mobile fell on to the water! this is also be a one of the reason! The better idea is you instal new software to your mobile! then the problem does not came!
Thanking you...........
May 24, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
134 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
