Question about Kenmore 24032\24036 Top Load Washer
My machine was vibrating during spin. so I took
My machine was vibrating during spin. so I took it apart and the springs had come off. I need a guide for where the springs attach too.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The section on the Base should have a diagram of where the springs and vibration pads attach.
Ths following Whirlpool Service Manual for top load direct drive washers also has a section on the base and where the springs attach.
Posted on Nov 15, 2009
Where is my suspension spring on my washing machine
The suspension springs on your washing machine are used to either suspend the tub assembly from the cabinet or to stabilize the tub assembly to the washer base. They also absorb the vibration of the wash basket while the machine is in the spin cycle. Occasionally these springs will become damaged, stretched or detached which can cause excessive noise and vibration from your washer during the spin cycle. You will need to remove the top or front panel of the washing machine to gain access to the suspension springs. Inspect for stretching or damage and ensure that they are securely attached at both ends. Use caution when replacing the springs as they are under tension and always wear the proper protective clothing. We recommend that you replace all of the suspension springs if any are determined to be defective.
Jan 13, 2017 | Washing Machines
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
My GE front loading washer model # WBVH6240HWW just recently started having vibration problems while in the spin cycle. Its vibrating badly and its very loud. What is causing it.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 07, 2010 | General Electric WBVH6240HWW Front Load...
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Very loud vibration during the spin cycle, how do you control this only 2 wks old
check the inside of the machine (have to unsrew the top of the machine)each corner should have a rod wich the drum balances on perhaps one has come loose or a spring is gone. possible lol i hope this is some help to you
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 27, 2008 | Washing Machines
Whirlpool Duet HT GHW9200LW
I had a bad "clanking" sound during the spin cycle on my
GHW9200LW so I took the back panel off and found that the H2o shield for the drive motor had worked itself loose. I removed Poly-V belt and removed one bolt and motor comes out easily. I found one of the 3 screws that attaches the shield on the floor of the washing machine cabinet. I reinstalled all 3 screws and reinstalled motor and belt. Noise fixed.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
