Question about D-Link DP 301U (DP-301U) Print Server
Scanner i am using panasonic kx-mb772cx all in one printer in a network, can i use scanner in that mechine through D-link DP-301u print server
  • Anonymous Mar 07, 2008
    I have the same issue with a Epson CX5600 all-in-one printer
  • nichole jose Dec 20, 2008
    i am using KX MB772CX printer all in one,, i wanted to share it w/ my officemate's pc... what to do??
    Scholar:
  • 101 Answers
This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
Posted on Mar 14, 2008
1.my dp-301u print server is in net A and it works well; 2.i just have an other net B ,it joins net A by a route ; 3.users in net B can connect to other server in net A but they can't connect the print...
Port 80 may be open behind the router to network B, but the ports used for printing may not. See if the router is blocking any ports and disable this feature for printing ports or all ports if possible.
Alternatively, try setting up a virtual server on the bridging router that points to the static ip address of your printer on network A.
Hope this helps. -Daniel
Jan 26, 2011 | D-Link DP 301U (DP-301U) Print Server
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
Using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP-301U Problem
    It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
    Is this the wireless print server?
    What specifically do you mean by PJL printer block?
    Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    DP 301U and Lexmark 2550 (all-in-one)
    1. Set up your print server with an IP address.
    2. Ping your printer IP address.
    3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
    4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
    5. Print.
    Hope this helps.
    Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
    DP-301U Printer Compatibility
    Yes it will work. In my office i am using 1160 series printer .
    Apr 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    Multifunction printer
    For this print server it will not support any other function of the printer other than the printing part. If you are trying to use the scanner look for multifunction print server.
    Aug 28, 2007 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    741 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
