Question about Microsoft Xbox 360 Console
I just asked a question about my vcve a x-box
I just asked a question about my vcr not x box please advise
  • Microsoft Master
  • 19,396 Answers
Hi.
You may need to state the problem again, since I cannot see your previous message.
You will also need to tell us make and model of the VCR.
If VCR is a Mitsubishi, E2 is a mechanical fault, where the control board detects that the motor is getting stuck when running on unload direction. This can be caused by tape stuck in the mechanics, a broken mechanism, or a jammed gear.
On other brands, E2 often is not even a fault code, but indicates the External 2 line (usually one of the two SCART input output).
In that case the VCR is simply tuned on E2. You will be able to switch to a different input using the Input/Source button on the remote.
Posted on Dec 09, 2009
Connection of a DVD/VCR player.
I used a Dynex RF Modulator, Model WS-007. Got it at Best Buy.
Oct 04, 2012 | GE 25GT240 25" TV
Do I need to throw out my GoVideo because it is not digital. Comcast recently went all digital and I cannot get any response on my VCR. Channel 3's view stays consistance from the TV Channel and doesn't...
Not if the unit itself still works; that is, it still plays videotapes and DVDs (with picture and sound).
Check your TV, you may have the wrong input selected for your unit (and/or other connected devices), or the TV is on the wrong channel; hence why you can't see anything from the VCR.
As for the ComCast box, give them a call and ask about it - quote the box number, and ask if it is digital or analogue - if it is the latter, they should replace the box free of charge as part of your cable subscription.
You do not need a new combo unit, unless you want one later which has a digital tuner. All it means is that you have no analogue TV channels in your combo unit.
Apr 04, 2011 | GoVideo DVR4200 DVD Player/VCR
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Initial setup
well you would want the digital box to get the best signal, so from the wall plugs into the digital box, the digitalbox can the be plugged in to the vcr or the tv where the vcr would normally go. dont get thrown off jujst because it doesnt say digital box, the tv might have a component setup on the back, or hdmi or svideo to hook up to, if not, just run it through the analog port of av1 etc
Oct 20, 2007 | JVC HD-61FN97 61" Television
RCA dvd-vrc combo model DRC8320N
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
