Question about Acer Aspire One AOA110-1588 Notebook
This note book does not have a disc drive, so how can I use any kind of restore?
  • joecoolvette
    joecoolvette May 11, 2010
    It is my understanding that using the Acer eRecovery partition, will wipe out all personal documents, (My Pictures, My Videos, My Music, and any documents in My Documents folder) Also downloaded programs, and applications, plus programs, and applications the owner has installed. Hence my additional questions in a Clarification post, on your Awaiting Solution.
  • 458 Answers
Aspire One's Have a Recovery Partition that's accessable by using the ALT and F10 Keys Upon Booting...
Try it several times if not sucessful the first time ... Though your model might not have a recovery partition, in that case you will need to either reinstall windows using A USB Flash Drive Or by using an external CD/DVD Drive
Posted on Nov 15, 2009
I am having trouble getting my LG multi drive to boot an OS. Im trying to load XP but it hangs up and tries to read the XP disc over and over. I went in BIOS and selected the DVD drive to boot up FIRST and...
pls note that these kind of problems are usually caused when either the xp cd disc is bad or the DVD/CD drive is weak. so pls kindly try with another cd drive and along side another bootable windows xp.
and all will bwell
Dec 26, 2010 | Intel DH55TC Motherboard
I have an acer aspire one D250 laptop and I tried to reboot and restore it. Now it lead me to a blank page that says B00TMGR is missing.press Ctrl alt del to restart. I tried to use ALT F10 and nothing...
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Sep 30, 2010 | Acer Aspire 3050-1733 Notebook
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
HAVE PURCHASED A DELL NOTE BOOK AND WANT TO INSTALL LEXMARK WIRELSS PRINTER Z1420 NO DISC DRIVE ON NOTE BOOK? hELP PLEASE?
You can download the software for your printer here:http://www.downloaddelivery.com/en/cpddrivers/580.htmlSimply click on the download for Vista , download it and run it....once that is done you will be able to print!
Thanks
Jul 04, 2010 | Lexmark Z1420 Printer
Going to reset my computer. Where can I find the reset button?
If you're trying to restore the Computer to factory settings, then you can use the VAIO Recovery Center that is shipped with the Computer.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option: NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Windows Vista® operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
May 17, 2010 | Sony VAIO® VGN-CR120E PC Notebook
Restore factory settings
Do you have the windows install disc.If so place it in your cd or dvd drive.Reboot pc.
Follow on screen instructions for reinstalling windows being sure to format your hard drive.You will loose everything.
Try a trial version of panda antivirus first, run a full scan.
Note.. some e machines are not sold with a disc,there is a system restore option on some e machines.
Jan 14, 2010 | eMachines ET1810-01 PC Desktop
Corrupt or missing file but have no disc drive as it is a note book please install a copy of above program windows root system32 ntoskrnl.exe
IF YOU ARE USING A NOTEBOOK, IN MOST CASES YOU SHOULD HAVE A RESTORATION PARTATION ON YOUR HARD DISK.
If this file on your CD/DVD is corrupt, the chances are good it will find many more needed to complete the installation.
Find your restoration partation or get a good working copy or XP to install from.
Oct 20, 2009 | Microsoft Windows XP Home Edition
I want to wipe the hard drive clean and then use restore disc to install the operating system. is this ok to do?hp dv6000 pavillion note book.i tried to restore system but keep asking for supplemental...
In case you have lost the supplemental cd, here's a helpful resource. You can use this software to backup your existing drivers and restore later. http://small.drivermax.com/soft/dmx/drivermax.exe available at http://www.innovative-sol.com/drivermax/
May 03, 2009 | HP Pavilion dv6000z Notebook
Dvd writer is not working
dear driver is not detect in laptop the becuse the some of the driver pinset ins not complet ley attech in the laptop board and fist of the remove the dvd writer and clean the socet thruout the panchil rubbar and afrer reinstall the driver afrer drive is working .......ok
Apr 08, 2009 | Computers & Internet
Restore3
I found these instructions for you on the Sony support site.
Solution
sp.gif sp.gif IMPORTANT:
  • Before performing a recovery, go to the Sony® eSupport Web site at http://esupport.sony.com and check your model-specific support page. Look for software and driver updates or check for knowledge base solutions that may help you solve your computer's issue.
  • This model does not require Recovery CDs. Recovery data is included on a special partition of the hard drive.
  • Do not interrupt the power during the recovery process.
  • Before performing a recovery, disconnect any external devices not supplied with the computer such as printers, network cables, cameras, or external storage devices, like hard drives or flash drives.
  • Customers who purchased the Symantec® Norton Internet Security® 2007 software from the Sony Style® store with their computer must create a Norton Account to save their product key prior to a system recovery or the software cannot be reinstalled.
NOTES:
    NOTES:
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Microsoft® Windows Vista™ operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
Please update me on the same.
Regards
Sammy
Jul 10, 2008 | Computers & Internet
Acer Aspire One AOA110-1588 Notebook Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
