Planar touchscreen LCD monitors 15 SERIAL In a Planar touchscreen LCD monitors, made for medical use. Model 01-01672 . I need to connect the Serial Cable. but I dont have the original cable.. I need the configuration to connect the 3 wires to a serial port.. THE CHIP IN THE BOARD ITS RES4CHPSMT 16964R12 , Brand Microtouch pin RES 150PL8 , 95409D, the bard have this numbers RES4-232-BRD , MADE IN MALAYSIA , OTHER STICKER WITH 17218 R1.6 , 040518 , THE BOARD HAS TWO CONNECTORS ONE WITH 4 PINNS TO VOLTAGE . AND OTHER WITH 5 PINNS TO THE SERIAL POART ... BUT THIS ONE ONLY HAVE 3 WIRES CONNECTED ,, ONE RED , BLACK AND WHITE . I need to conect this 3 cables to the serial port DB-9 pin , I want to know how to connect in a PC ALSO I NEED THE DRIVERS TO USE IN WIN XP. Thanks
  • 4,924 Answers
Take a look on this ..planar ..also used in medical care ...see that on this page there is a manual link .. and in there are more than one models made for this purpose and from Planar...
anyway ..they have images about connectivity and power ....meybe you recognize something ...
anyway ..under there is a link with a driver ...and cause its not sure what your model is ...( I could not locate anything by the numbers and serials you offer there ) maybe you will locate from the list ...something may pop up when you take a look ...
anyway ..being a touch screen ..and a 15 inch ....here should not be that hard to locate driver by elimination ...and maybe some series letters ..about cable ...I found nothing ..but Im keep looking ...od the manual I sow that some of them are connected by regular vga ..and usb dual.....
take a look in that manual ...its a pdf ...and keep the drivers location ..Im sure that after you know the exact model your driver is in that list
anyway ...
Posted on Nov 16, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
The monitor has no picture at all and the light goes from green to yellow
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Touchscreen off
replace/repair the touchscreen glass / controller
Dec 01, 2008 | Planar PT1700M 17 in. Flat Panel LCD...
Power supply pings distributions planar d6015tm
The information comes on the same manual of the planar monitor d5015TM (see as medical monitor)
Sep 12, 2007 | Planar VitalScreen D6015TM (White) 15 in....
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
