Power failer when switching on tv
Fuse in plug is blown when switching on television have tried a couple of fuses. No other fault. Goodmans 28"
    Scholar:
  • 57 Answers
A fuse blows when there is a fault and it is the first line of protection for the equipment. The fuse used in a typical plug is rated at 4A/220V. This means that a indeed fault does exist inside the equipment that is forcing it to draw a current greater than the rated. Almost certainly, the primary circuit of your Goodmans is at fault. If you are familiar with TV repair then check the bridge rectifier as well as the reservoir capacitor, with the switching semiconductor (BJT or MOSFET or IC) removed. If the fuse blows then the rectifier/capacitor are to blame. If not, then the semiconductor is at fault. If you are a novice, then rather refer servicing to a qualified tech since the risks outweigh the benefits.
Posted on Jan 09, 2008
Power off and not coming back. Changed power connection, checked switch, no power light. Where do I get a power supply for the tv and what does it cost. For initial cost of $900.00 I expected the tv to...
keep it unplugged for about 30 minutes to reset the tv. then try again. also you may have simply blown a fuse inside the tv. open up the back panel right where the plug connect there will be a fuse. if its blown just replace it. if its not blown and the 30 minutes dont work. its not worth finding a power supply (i looked and cannot find one anywhere) and if you do i have seen power supplies for other tvs upwards of a couple hundred you can easily buy a 37 in 1080p tv know for around 350
Mar 16, 2011 | Protron PLTV3250 32 in. LCD Television
Goodmans crt tv dead
there is another supply missing from your power supply, chec your components on that power supply a ht of 90volts is missing,
check all active components like transistors,diodes and resistors with very small values,
if you go through you are going to win that problem, ok.
Apr 03, 2009 | Goodmans 257NS 20" TV
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Goodmans ld3750hd
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the problem with the component that mentioned by you, write down the Number written on that and replace it with the same by the help of a Soldering Iron.
Also see the writing near to it for finding out what the component is.... For eg. C=Capacitor, R=Resistor, TR or Q=Transistor, IC=Chip, D=Diode etc.
Apr 13, 2008 | Goodmans 257NS 20" TV
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Goodmans 1430R TV (bought 10 years ago) switched off in middle of program by itself and no longer works.
Oh come on man the sets tired!!!LOL no really you got plenty of use out of this bugger. Your problem sounds like something opened in the power supply and since the sets all solid state theres no user serviceable parts inside them. If you really wanted to put cash into a 10 year old set for an estimate/? i would not . But if you like the set go for it. Good luck
Jul 27, 2006 | Goodmans 1475TS 14" TV
TV has no power
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Nov 16, 2005 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
