Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
My shower monitor valve keeps losing presure - Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Loss of water presure
Depends upon the brands of the shower fixture
Apr 06, 2014 | Maax RainForest - Three-Piece Corner...
2000 oldsmobile timing chain symptoms
sound as if you have an air lock had the exact same problem with my mates fiat have a look online to see if there is a presure valve and just release the presure thsi is a bit of a pig to do as it may take a few goes to get the air out
Aug 25, 2012 | 1999 Oldsmobile Alero
How do I take apart a Delta Monitor Shower Handle
Take a look at this link:
http://www.ehow.com/how_6155493_replace-delta-shower-valves.html
Your valve may vary somewhat but this should give you a good start.
Apr 02, 2011 | Delta & Single Handle Shower Faucet
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
Jan 29, 2011 | Delta & Single Handle Shower Faucet
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
Shower keeps coming up with low pressure and water goes
think ur presure redusing velve [prv] is durty and ur hot and cold water is not balenced presure . the prv is 90% of time located in 1m radius on cold water seply to geyser look for a curtrage , unscrew clean out and put back. will fix the problem
Plz rate my advice
Jun 01, 2010 | Home
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
My GS thermostatic valve in my shower is slowly but surely losing its ability to keep the temperature hot. I have to turn the temp up higher and higher to keep it comfortable and now it is all the way up...
Chances are that the thermostatic motor or element is failing and probably needs to be replaced. It will be necessary to turn off the water (hot and cold) to the shower valve, remove the handle, maybe the decorative plate (will depend on your model), then remove the valve assembly. If it's a cartridge, you willl need to remove the center clip and pulll the unit out with a pair of pliers. They do make a removal tool, but you may not need it. If the valve is a flange type, you will probably need to remove three to four screws and then genetly pry the valve out of its mounting. With this type of valve, there may be an "O" ring around the assembly that should be replaced so keep that in mind.
Some thermostatic valves can be repaired by replacing their individual components. Again, it will depend on your model.
Take the assembly to your local hardware or home improvement center along with as much information as you can, and have them match up the part(s).
Re-assemble the valve, then turn the water on before you re-install any handles or plates and check for leaks as well as proper operation. You can just slip the handle over the valve stem to test.
Nov 08, 2009 | Home
About every 3 months, the shut-off valves on my Grohe shower valve begin to leak. I've replaced the valves several times, but it still happens. Can I get replacement o-rings?
it sonds like you need to adjust your prv[ presure reducing valve ] , as to much preasure sonds like the culpret. and yes replacement orings are usualy available thru your local dealer, but you won't find them at a hardware store like say home depot or home hardware.
Sep 17, 2009 | Plumbing
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
76 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
