Question about Samsung BlackJack II Smartphone
Yellow light. Won't charge. Ugh. - Samsung BlackJack II Smartphone
  • 105 Answers
A yellow light indicator usually means that the battery is charging incorrectly could be caused fromgetting wet the whiten sticker on your battery compartment if it is red then it got wet or being dropped the only solution to this problem is to get a new battery and it should work fine after that go to ebay to get a new one cheap hope this was helpful:)
Posted on Nov 18, 2009
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Yellow security is light flashing, battery is charged, hazard light fuse isn't located under the hood for my1990 300zx won't start
If the security light is on then the car thinks someone is trying to steal it. If you can’t make the remote work then you might be able to clear it by disconnecting the Negative battery cable for about 10 minuets
Feb 04, 2018 | 1990 Nissan 300ZX
What is green and yellow? Battery won't charge!
This indicates the battery is defecive.
Jan 27, 2012 | Ryobi Drills
When I install new batteries it won't stop 'squealing'...what could be the problem? Ugh - I can't even use it like that!! thanks!
It was a Garrison - I've since learned that the problem was it was screwed a little too tight and was pushing against the circuit board. I took the back off (where the batteries are) and loosened the screws a little and the squealing stopped!
(Posted to clear the "unanswered questions" and share with the community)
Nov 25, 2011 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
My Rascal 318 has two constantly flashing yellow light and will not work. Help
Hi wrosser2
Two constant yellow flashing lights indicates three things
1. Low voltage. Load test your batteries even if they are new. You may need to take them out and charge them on a car charger. Your charger won't work without at least 20 - 22 volts. Your inhibitor on the charger won't close to make continuity to turn the charger on.
2. With an olms meter check your front to rear harness for continuity. If you have a bad wire, replace the front to rear harness.
3. Third and most costly is a bad controller. No way to check that without replacing it. Check 1 & 2 first.
Good Luck
mimobility
May 03, 2011 | Medline Industries MDS808450 Excel...
Roomba Battery (existing and brand new one) Not holding a charge.
The Charging circuit on the main board is dead. Either replace the main board or repair it if you have the skills and equipment.
Jan 06, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Samsung BlackJack II Smartphone Logo
409 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
