Question about Mad Dog Multimedia Dominator (MD-12XDVDRW-SE) (MD12XDVDRWSE) DVD±RW Burner
Battery works spark plug is good wont start - Mad Dog Multimedia Dominator (MD-12XDVDRW-SE) (MD12XDVDRWSE) DVD±RW Burner
  • 6,826 Answers
Need to know what year ,make and model,and some more details on what is going on,thank you.
Posted on Nov 15, 2009
Spark plug blew out now car wont start
sounds like the autoshutoff relay may be bad..it controls the ingition and the fuel pump too..if the pump works check for spark by inserting a screwdriver into a pulled off spark plug wire and look for a decent spark between the screwdriver shaft and any ground like the block..if no spark the relay may not be powering up the ignition system..
Dec 15, 2013 | Acura RSX Cars & Trucks
APRILIA CLASSIC 125 WONT SPARK
Hi, Downey if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2000+aprilia+classic+125
Apr 20, 2013 | 2000 Aprilia Classic 125
1993 klx 650 wont start
some bikes need a certain amperage from battery for the pickups to work, is battery good, and correct type
Feb 14, 2013 | Motorcycles
Truck wont start engine turns but wont fire
If the trucks turns over and does not seem like the battery is dead I would assume it is spark or fuel. Check spark plugs to make sure they spark. Pull one plug at a time hold it against side of engine and have someone turn the truck over for you. You should see bright spark from all spark plugs. If you do see spark then check your Fuel Pump to make sure it is getting power and is opperating correctly also check your fuel filter to make sure it is not plugged. Good luck, Hope this helps.
Sep 05, 2012 | 2005 Chevrolet Colorado
My Mitsubushi Space Star Car won't Start. What can I try?
spark plugs are deep in the head yet you should get all the the old fuel out first, stale fuel wont ignite and will also clogg fuel filter. you need a mix of atleast 70% new fuel even then its not good for the injecters. If its a manual gearbox a tow start is a quick fix although no go for auto's. cant be much wrong if car was fine when parked, plugs-fuel-filter and possibly fuel pump for sure. If that doesnt fix take plug out put in lead and crank engine to be sure you have spark even just put any plug you know works in lead leaving your plugs in engine just to check for spark y turning over engine looking for spark on plug good spark will be blue but any spark is good.
Jun 16, 2012 | Mitsubishi Cars & Trucks
Our 2008 dodge charger wont start,and the radio wont work,checked all fuses/circuit breakers/relays,all good,but it still won't start-cam somebody-PLEASE help me???
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 05, 2012 | 2008 Dodge Charger
1994 diamante wont start. battery is good, car started earlier today. tried to start car, lights all work, fuel pump turns on, car wont start. any suggestions
check to see if there is any spark from the spark plug. Take out a plug and hold it (in pliers) close to a metal part of the motor and get someone to turn it over. you should see a small spark. If not then check dizzy cap and rotor
Sep 10, 2011 | 1997 Mitsubishi Diamante
Try to start the car, engine turns but wont start
start with the basics, does the fuel pump work, do you have spark, do you have injector signal, are the fuses good, lots of variables here
Nov 22, 2009 | 1994 Oldsmobile Cutlass Supreme
Truck turns over but wont start
check for spark, check for fuel, check fuses and relays, replace old oil,old fuel
Sep 20, 2009 | 1997 Chevrolet S-10 Pickup
Computers & Internet Logo
Top Mad Dog Multimedia Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
