Question about Nintendo Wii Console
Will not power up
Our Wii will not power up at all. Any suggestions?
  • 8,197 Answers
My wii won't turn on and I tried unplugging and disconnecting all the cords and it still won't work...any suggestions???
First verify the outlet on wall you are plugging the Wii into works.
Unplug the power cord from Wii AND the wall to allow proper discharge of the power unit. If you do not unplug from wall outlet to then the power unit will not discharge.
It could take up to 15-30 minutes sometimes.
Mar 01, 2011 | Nintendo Wii Console
The wii was working fine then all of a sudden there was no power going to the console. I unplugged it, waited awhile then plugged it back in again, still no power. Can it be the power cord?
Yes accually it can be the power cord.Depending on how old it is and how twisted or bent it is can be the broblem. I would suggest getting a new power cord befor getting a new wii and consulting a wii specailist be for getting a new wii
Jan 22, 2011 | Nintendo Wii Console
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
No power, will not switch on
Change outlets, if it still will not turn on, buy a new power cable, if still your console will not turn on, your power source in the wii may be broken and need replacing. I'd suggest calling technical support or trading it in.
Mar 31, 2010 | Nintendo Wii Fit for Wii
My son was using his wii when the power suddenly went out on the TV and the wii. The TV started working again, but the wii did not. I've checked all the connections and unplugged and plugged everything in,...
Did you have a power surge? Unplug the power supply from the wii and the wall for five mins. Then plug it back in and try it out. Have heard of this working for some people.
Mar 14, 2010 | Nintendo Wii Console
No power to the Wii
Yeah, it is sort of a common problem if you don't play your Wii much, simply unplug your power supply from the Wii, and the outlet, then wait a couple of minutes, and hook it back it, it should work then!
Sep 03, 2009 | Nintendo Wii Console
My wii won't power on, the power source is fine
After lots of surfing around, I found a suggestion that said to unplug the power supply from BOTH the Wii AND the wall for a few minutes because the power supply block has to reset itself. (I had only been unplugging it from the back of the Wii) Try it!! It works!!!! | wish I could find it again because I'd like to thank the person! Too bad Nintendo doesn't tell you this!!
May 09, 2009 | Nintendo Wii Console
Stuck disc
Unplug Wii Power.
Plug back the console power, start back and press repeatedly the start button while the console is starting. Before the laser lens starts reading.
If that does not work, then there is need to disassemble the Wii, in that case call Nintendo first.
Here useful websites:
this article
Wii Disc?
Apr 05, 2009 | Nintendo Wii Console
Ejecting Wii disc while power is off
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 29, 2009 | Nintendo Wii Console
Wii not powering off
You have to hold the power button down on the Wii console for many seconds before it will power off completely. Try it for more than 5 seconds.
Nov 29, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
