Dell inspiron 5100
I have a problem with one side of the memory card place. My pc just recognize one side.I swap the memory position and detected that is one side.
What is the problem or what can I do resolve it?
Thanks in advance.
Lcd not brightness
Posted on Dec 23, 2008
  • 21 Answers
If the memory is seen when you put each module in the 'working slot' of the motherboard then the other memory slot sounds bad and you'd need a new motherboard to fix this issue.
Posted on Jan 09, 2008
Dell Inspiron 5100, want to update (need new m/b?) cpu and video card. Is it possible? it's got an 800x600lcd display with vga out to 2nd display
You could replace all that but the display will still have to be 800X600 as the laptop screen will not handle any more. Mother boards are generally specific to the laptop as is the processor. Memory could be upgraded maybe.
Why not trade it in for a better model? It could work out cheaper in the end.
Hope this helps.
Nov 19, 2010 | Dell Inspiron 5100 Laptop
Dell Inspiron 5100 won't start. Capslock flashes 10 times.
it is because the slot in which your memory is loose.try changing the slot of your ram
if this wont work,then some pin of your ram is loose.go to local computer shop .they will tighten those pins
Jul 25, 2010 | Dell Inspiron 5100 Notebook
I want to upgrade my dell inspiron 5100 from 256 x 2 to 512 x 2- do i need to buy from dell or would any brand do
No you most certainly do not ned to buy from dell...
hynix is a Good Brand To Use...
You can Even Go To Ebay And Get Your Memory..
Dell Will Wayyyyyy OverCharge You....
Dec 02, 2009 | Dell Inspiron 5100 Notebook
Install internal mini-pci wireless card,dell inspiron 5100 laptop
open bottom of laptop where ram and cpu is located usully in middle 2/3 screws there should be a slot arouns an inch long on board that this slots into however does your laptop have the wireless cables that run from motherboard to hinges that hold screen in place usually black1 and grey 1 which are main and aux grey is usually main
Oct 02, 2009 | Dell Inspiron 5100 Notebook
Wireless connection
hi,
welcome to fixya.com
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
6600 MMC not detected in Laptop
Ur Memory Card Has the ERROR i.e : Its Corrupted -
Ur Memory Card might Contain Viruses or Autorun fault -
U Should Format ur Mem. Card from Mobile then PC then Mobile -
Like dis way it will Work both in Mobile as well as in PC -
Jan 14, 2009 | Nokia 6600
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
SYSTEM DOESN'T RECOGNIZE NEW MEMORY MODULE
Memory modules must be the correct type and speed, and be within the specifications for the laptop. Just because it fits in the slot doesn't mean it will work.
The Dell inspiron B130 has 2 slots. Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. if you tried to insert a 2GB module, it will not work.
If the module is within these parameters, remove and re-seat the memory, and try swapping the modules from one slot to the other. It may be a bad slot.
Dec 28, 2008 | Dell Inspiron B130 Notebook
Dell Inspirion not recognizing both memory slots
MAKE SURE BOTH SLOTS ARE ENABLED. ALSO MAKE SURE THERE IS NO CONFLICT FOR THEM IN DEVICE MANAGER
Dec 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1100 Memory speed
You need to look at the memory card(s) you have and only the same pin memory will install. Faster memory isn't as important as the maximum amount you can add, since your cpu can't run any faster, but windows can use the extra ram and avoid disk-swapping which is slow.
Nov 03, 2007 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
