have an Access 2003 database that appears to be very corrupt. I was having a problem and did a compact and repair on it, and I lost my network connection during the process. Now when I try to open it (or access it via DTS, VB, anything I can think of), I get
"The Microsoft Jet database engine stopped the process because you and another user are attempting to change the same data at the same time".
I have rebooted the machine that was accessing it, and no help. I can't reboot the server now because it's a 24/7 file server. Is there any way to get this database open? I have searched and found a bunch of demo programs that will "uncorrupt" it and show some data (but not save it), so I know it's possible, but is it possible without buying one of those programs? thanks
Whenever you open an Access database, a file with the same name as the database and an extension of LDB will be opened automatically. For example if you open Northwind.mdb in the samples directory of your Access/Office installation, a file called Northwind.ldb will be generated. This new file keeps track of users and the objects that require some form of locking in the database. When all users have exited gracefully from the database, the LDB file is closed down and deleted.
thanks for rating
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Access 2003
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file...
(More)
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file that's in the format shown below? I'm trying to import this file into an Access database table. The file has spaces between each line which is what is giving me a fit. Please look at the file layout and example below. Text File Layout: a = Lockbox #: (6) digits and (4) leading spaces. Postions 1 - 10 b = Site ID: (2) digits and (8) leading spaces. Postions 11 - 20 c = ISA #: 10 spaces. Postions 21 - 30. Not used currently d = Cust #: 5 spaces. Postions 31 - 35. Not used currently e = RG Key: 11 spaces. Postions 36 - 46. Not used currently f = Tran Code: (4) digits (4) spaces. Postions 47 - 50 g = Record #: 4 spaces. Postions 51 - 54. Not used currently h = Count #: 2 Spaces. Postions 55 - 56. Not used currently i = Volume (17) digits, zero padded to the left of volume. Postions 57-73 j = Dollars (14) digits, zero padded to the left of volume. Postions 74-87 k = Description: 240 spaces. Postions 88 - 327 l = GL #: 23 spaces. Postions 328 - 350 m = Adjustments: 3 spaces. Postions 351 - 353 Text File Example: 105243 12 4101 00000000000009552 105243 12 4102 00000000000000325 105243 12 4108 00000000000043838 105243 12 4110 00000000000043838
I am getting the message "Module not found" after deleting a form that I no longer use...
(More)
I am getting the message "Module not found" after deleting a form that I no longer use anywhere in the database. If I put the form back - issue goes away. If I rename the form - comes back. Something is calling this form but I can't see what. Nothing references it in VBA, macro, query, etc. Where can I look next to see what is calling this thing?
