Question about Vehicle Parts & Accessories
Need to by-pass the factory alarm so i can hook up a remote start
    Problem Solver:
  • 11 Answers
Need to know make and model of car to anserw.
Posted on Nov 16, 2009
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Jan 28, 2014 | 5301 LE 2 Way Car Remote Starter System
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
HAVE A 1998 CHEVY CAVALIER; \r\nTHE POST ON THE
you have to use the key to unlock and lock a door.that is if its a factory alarm. after market add on may not work that way and may need the remote. if drivers door dont disarm it try the key on pass. side. doors have to be closed when lock/unlock with the key
Jun 09, 2010 | 1998 Chevrolet Cavalier
Tried to clean battery posts,went to hook back up alarm went off.tried to unlock doors no luck,tried to start nothing just alarms
Find the Valet switch under the dash and depress / hold it in while someone else hooks up the battery. Then try and start it. Your going to have to break out the manual for your particular alarm (unless it is a factor alarm) and re-program your remotes.
If it is a factory installed keyless entry / alarm then the procedures are in your owner's manual.
Kelly
Feb 11, 2010 | 1995 Ford Windstar
When I try to use my autostart my panic alarm sounds, It does it with both remotes and I changed out the batteries. any idea?
try unlocking the doors with your factory remote first then press your remote start button, if it starts without your panic alarm sounding you need to check under the dash and make sure that the disarm wire is hooked up securly to the purple wire at the bcm
Dec 29, 2009 | 2006 Pontiac Grand Prix
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
