Question about Hotpoint Ultima WF860 Front Load Washer
I am getting an F-05 error - Hotpoint Ultima WF860 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
Error code F05 indicates that the pressre/waterlevel switch is jammed on full.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean plastic filter inside hose.
Remove hose onto pump, check for obstruction here, and into the pump.
Please leave feedback.
Thanks.
Posted on Nov 16, 2009
Thats what happened to my machine it fills with wat We're r but doesnt drain or rinse prop We're properly
Posted on Jan 02, 2015
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
I get the message error 05 stuck key on my precor efx 546
Corrective Action
Dec 09, 2012 | Precor EFX 546i Elliptical Version 4
I am HP partner tech and have a problem which HP are not interested in. Fitted a new electronics module and now get 05:10 error which is bad/missing formatter, printer has never had a formatter. I press...
System Error: 05:10 Error (Only applicable to HP DesignJet 500 Series)
Problem Description:
HP-GL/2 Accessory Card failure.
Corrective Action:
Power OFF the Printer and replace the HP-GL/2 Accessory Card
Remove the Formatter
Aug 08, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
I am getting a reading on the screen of "er 05" i
Corrective Action
Mar 21, 2011 | Precor 9.31 Treadmill
Getting stuck key msg for my EFX 576i. I've unplugged the keyboard and plugged it back in but no help
Corrective Action
Jan 12, 2011 | Precor EFX 546i Elliptical Version 4
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
The port the modem is attached to could not be opened; Opening the modem device failed with error 000005aa
Sounds like a hardware problem
First > try changing the modem port (default is com3, try changing it to com4 or com5 whichever is free)
Try querying the modem again
Second > Contact your modem manufacturer
May 26, 2008 | Conexant chipset 56K V.92 PCI Data/Fax...
Hotpoint Ultima WF860 Front Load Washer Logo
400 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
