Question about Garden
How can I find a owners manual for the perma green spreader, model # ROC 60 A1B?
3 Suggested Answers
kb8dns
  • 494 Answers
SOURCE: How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Posted on Feb 14, 2010
SOURCE: lost manual
I have a Scotts speedy green 3000. Got it $5 used. I just called Scotts, and they are sending me a manual. But, they told me how to calibrate it. First, you need to know if you have the same "version" as I do. Apparently they made the same model more than one way. I'm told I have a newer one. The way the Scotts rep differentiated was by the wheels. I have all black wheels with orange hubcaps. Older models have orange wheels. If you have the model I have, then do this to calibrate the spreader:
1. On the black slide that comes up when the handle is pulled to open the spreader and releasing product you will find a curved line about 1/2 and inch from the top.
2. Set the spreader to a setting of 2 on the handle.
3. When you pull the lever as if you were releasing product, the indented black line should line up with the curved part of the green hopper at the top of the opening.
4. If it does not align, then you need to adjust the cable that run from the handle down to the hopper door. This is done using pliers of wrench by turning the square nut at the bottom of the cable. It's trial and error at this point.
Mine was off by 30%.
Good luck
Posted on Aug 02, 2010
Tilting backseat
glove box book
Hilux D4d Manual - lux-roc.com
www.lux-roc.com/hilux/hilux-d4d-manual.pdfToyota hilux tiger d4d sport cruiser manual pdf ' pdf owner ... Dec 05, 2014 Download Link: Pdf Download Toyota Hilux 2005-2011 Auto Repair Service Manual, ...
Oct 10, 2016 | Cars & Trucks
We have a Scotts Easy Green Lawn Spreader..(Probably have had it for almost 10 years...don't know how to tell what model, but the adjustment lever and knob are on the back. The single push handle is...
Call Scotts at 877-465-5160, and we will be more than happy to send the manual to you! Also, if you are using Scotts products, then the spreader settings are listed on the back of the bags.
Hilary @ Scotts
Aug 15, 2011 | Garden
Where do I get a part for scotts speedy green spreader? A plastic part broke which controls the fertilizer shut off spout.
Scotts does have some replacement parts available, depending on the SpeedyGreen model you have. Please give Scotts a call at 800-543-8873 and we'll be happy to assist you with replacement parts. Hilary @ Scotts
May 19, 2011 | Scotts Accugreen 3950 Spreader Green 73730
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts 3000 spreader needs calibration?
I found the manual that came with the spreader.. recalibrated it and it works fine.
Apr 28, 2009 | Scotts Company Scotts& Accugreeen 3000...
Lost manual
Good luck
Apr 19, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Garden Logo
219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
