Question about Brother HL-2040 Laser Printer
Error while printing message
I can make a test print of the history and a est prit of the cartridge "health" so I know there is no paper jam. I took he cartridge, shook it, and returned it to the printer. Previously I installed the latest driver brxubprt11. Prior to this the printer was preforming OK and I was able to print out 4o envelopes an 40 sheets of text. I opened the console log and below are the messages it gives when the pop up reports "error while printing"
(1) PMSessionBeginDocumentNoDialog failed (error code = -108)
(2) Failed to create PMPrintContext
I changed the printer USB cable, connected it to a powered USB hub with no effect. I connected the USB cable from the printer to the Mac direct in USB port with no change in the error message. I am running OS 10.4.11 on a G4 1.25 GHz dual processor , 2 GB RAM MDD. Up to now, this printer has preformed better than any ink jet printer that I added to inkjet printer graveyard.TIA.
Maggie and Otto
  • 5 more comments
  • ejlmp Jan 10, 2008
    Thanks for your answer. I'm not sure if the driver I had before was older than the one I just installed. I don't have the old printer driver. About this Mac shows the current driver is Driver Version 1.02.
    Eric
    I forgot that I have the HP install disk that must have the old driver. I will try that now. Thanks again.
    Eric
    I deleted the printer driver and reinstalled the driver from the CD with Brothers driver: no print. I reinstalled the driver from the Brothers Web site,and after all that saw the same fast to appear message "Error while printing" . Hmm, what printing? Thanks for your help.
    Eric
    I deleted the printer, started up in safe boot, re-installed the printer download from Brothers Web site, and restarted. When I try to print, I still get the "error while printing" message. In the about this Mac panel, the Driver Version is 1.02. Is this the up to date driver? Thanks for your help,
    Eric
    Thanks for your reply. Yes I reverted to the original driver on the CD that accompanied the printer. I again could not print even with the old driver. In the about this Mac panel, the Driver Version is 1.02. Is this the up to date driver? Thanks for your help,
    Eric
    I switched to a different hard disk in my Mac and installed the download on this second hard disk and the printer worked! Not believing my eyes, I opened a third hard disk in my Mac, and installed the driver. It worked on this HD too. So the orginal disk is somehow corrupted. The disk passes the rebuild using DiskWarrior and repairing permissions. Also I found a Brother utility in the printer library called "Brother Status Monitor" app. Clicking on this returned a popup window "Status Monitor" that showed a green bar with "ready" in the window. If the cable is disconnected, the bar will turn red. But even with all these go ahead signs, the printer will not print from this partition that is almost a mirror of the other partitions where the driver is installed and the printer works. I'm left to conclude that this partition might benefit from a clean install which BTW I just did last summer. OK, Macworld is coming to San Francisco next week and I will hang around the Brother booth and also ask the Apple "experts" a thing or two. Thanks for your help.
    Eric
    I would like also to know the cause. I spent most of December printing out envelopes, etc. for the holidays without any failures. Once the holidays were over, the printer breaks down. It also shows that customer service at Brother is woefully lacking and they do not get back to a service request in one business day. Brother has had 4 days to respond but so far, this fixya board is many orders of magnitude better than customer service at Brother. Brother can you spare a minute? Sorry not this year! Thanks for your help.
    Eric
    President:
  • 1,944 Answers
Did ou try reverting back to your older driver? If you did, does it still give an error message and not print?
Posted on Jan 09, 2008
  • Damen Wong
    Damen Wong Jan 10, 2008
    The latest printer driver is 1.1.0
  • Damen Wong
    I am happy to know that you figured out what the problem. I am also curious to know the cause of this.
  • 319 Answers
Please try to powerdown your Printer and then your computer. Please restart both.
If you still are having the problem, then:
Try deleting and adding the printer again and see what happens from the printer setup utility if you are not able to print under another user and repair permission doesn't work.
  • 4 more comments
  • Brian Berndt
    Brian Berndt Jan 09, 2008
    This error is a "Storage Allocator Error. Ran out of memory (not enough room in heap zone)"
    If problem does not desist after power down and restart, or reversion to previous driver, please advise.
  • Brian Berndt
    Brian Berndt Jan 10, 2008
    Ok, Good Luck!
  • Brian Berndt
    Please try to do a Safe Boot. Then re-add the printer.
    Please see instructions to do this here, if you are unfamiliar with Safe Boot.
    Let me know how this turns out!
  • Brian Berndt
    Let's be sure that the printer does not like the document you are trying to print.
    Have you tried to print a document other than the one that you were working on when the problem started.
    Open your word processor, Create a small document. See if you can :
    Print Preview
    Print to File
    Print to Printer
    The driver you are using should be fine.
  • Brian Berndt
    Going back to the beginning, you are using the install instructions listed here, right? I am not sure it will make a difference, but this is from the Brother website.
  • Brian Berndt
    I'm glad that you got it figured out!
    If you were happy with the help you received please rate me as FIXYA!
    Thanks!
    Brian in KY
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
My printer say that there is a paper jam. I cannot see any problem. No paper, lightly shook out machine, not paper clips, etc. but I cannot print because it say paper jam.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 04, 2011 | Canon PIXMA MX310 All-In-One Printer
I have replaced ink cartridge that was low but it still will not work ,keeps telling me that I need a new cartridge.Saying printer does not have enough ink to ensure printer health. The empty ink cartridge...
Press the left arrow and the setup button together..
You will find Support Menu.. press the arrow key to come to Prit test menu.. click ok on that ..
now, press the arrow button to choose Nozzle test..
even after that if it continues to show the error, and if you are not able to print anything from the computer..
You may try by doing a L2 uninstall and then reinstall ..
Aug 12, 2010 | HP Photosmart C5180 All-In-One InkJet...
The ink cartridges won't move.
I hav the same problem with mine! DId you find a solution?
Jun 29, 2010 | HP DeskJet 9650 InkJet Printer
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
Paper jams. Printer was cleaned, but it still jams.
Whare does the paper jam at?
It may be a fuser problem.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know..
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Samsung CLP 315 Laser Printer
Wont prit
reboot the computer and the printer..
then try to do a "Print Test Page"..if it still does not print, turn off the computer again, unplug the printer from the back of the computer ( I assume it's connected via USB), then plug the printer on a different usb slot on the computer.. you may have to re-install the drivers. make sure you have the cd for the printer.
Hope this helps.
May 09, 2009 | HP DeskJet 840c InkJet Printer
Lexmark z2320 printer
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below: 1. Turn off the printer.
2. Press and hold the power button for at least 5 seconds, then release the power button.
3. The Self-Test will print. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridge installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without the cartridge installed, run the self-test again with only a color cartridge installed. If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 12, 2009 | Lexmark X2550 All-In-One Printer
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Brother HL-2040 Laser Printer Logo
238 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
