Question about Electronics - Others
Need Device Code for Boston Acoustics DT6000 remote to program volume on my universal remote
Hey Mike,
I have the same system and my BA remote control just died. Did you ever find the code for the DT6000 to use with a universal remote?
Thanks for your help,
luis.castellanos@gmail.com
Posted on Dec 03, 2010
How do I program my tv remote
HI,
DIRECT CODE ENTRY
Step 1:Press and hold the "CODE SEARCH" button ("CODE.SRCH" for RCU500).
Step 2:Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 3:Enter the 3 digit code number
Step 4:Release the "CODE SEARCH" button.
Step 5:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test.
CODE SEARCH
If you cannot locate the code for your device, try thecode searchmethod below:
Step 1:Turn on the device.
Step 2:Press and hold the "CODE SEARCH" button.
Step 3:Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5:Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6:When your device shuts off, press and release the "ENTER" button.
Step 7:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
CHECK THE LINK FOR CODE
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
Sep 27, 2014 | RCA Televison & Video
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
Can program up volume but not down or mute
To program the down button, after step 1 of the programing sequence, you must press the down button of the speaker system and then press the down button on the remote four times. This goes for the other buttons (i.e. after step 1 of the programing sequence, press the mute button on the speaker system and then press the mute button on the remote four times).This is a weak point in the programing instructions.
May 25, 2011 | Boston Acoustics TVee Model Two TV...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
Where can i find replacement wires?
I hope that helps.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
Electronics - Others Logo
581 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
