Question about Kenmore 75844 / 75849 Gas Kitchen Range
What does the f1 message mean? - Kenmore 75844 / 75849 Gas Kitchen Range
  • 11,896 Answers
This is your part, and f1 code is the board. Always visually inspect the bad part though before ordering but this should fix ya.......good luck..
Electronic control:
http://www.repairclinic.com/referral.asp?R=154&P=496226
  • You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
Posted on Nov 15, 2009
Why is the F1 comes on at startup on my acer x498g
Is there any type of message with the F1 at startup. Normally I think F1 means to continue, so most times there is a message with it.
May 30, 2012 | Acer Veriton X498G Compact 4G 500GB
The last two days I have the error message F1-E9 on my kitchenaide oven. I press cancel and it returns to normal. What does this mean?
F1-E9 - Stack Overflow.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
Jul 15, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My PIU Cube 16 Olimpia Splendid portable air conditioner is displaying an error message f1, can anyone solve what this means? Thanks
It means 'Dirty Filter' once cleaned you must press and hold down the 'On' button for 5 seconds and the message will remove.
Feb 24, 2011 | Heating & Cooling
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
F1 message on Maytag range
This is what the code means.
F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Good Luck and Please Rate
Jan 08, 2009 | Kitchen Ranges
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 75844 / 75849 Gas Kitchen Range Logo
119 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
